If you are running true semi slick and only driving it on a race track I agree, anything else and imo the slightest bump and you'll be getting wheel spin.
What dampeners are you running? The issue with most 8/6 rates is they come in a coilover kit with crappy shocks.
That doesnt mean the spring rate is wrong. It means your shocks are too rubbish for the level of performance/grip you desire
If you are running a POS pogo stick brand of shock then it doesnt matter what spring rate you throw at it...it will be rubbish. Run a basic Bilstein or Koni and get them valved to suit a higher rate spring and it will be fine.
I run Tein RAs, was going to revalve my old Bilsteins but grabbed these as they have allow bodies. My car doesnt get wheelspin even in second on the street. Good tyres, good alignment and reasonable quality shocks and you can put 300rwkws to the ground without a lot of fuss.
Dont see the point of running the cheap coil overs. If you are spending $1200 may as well save up and spend 2k for a far better result. Then you can run whatever spring rate that suits the grip of tyre you run.
Yep, I run DMS 9kg front, and 5.5kg rears. Interestingly for the 32 GTR this is their (DMS) "targa spec" rates with valving to suit. So more of an all-rounder than a straight circuit setup. You certainly can't afford it to be drifting or spinning wheels in a Targa event I assure you.
And it feels very sure-footed - still with some good compliance.
As Roy points out, a good deal has to do with valving too. I think a lot of people try to 'over dampen' - using the shock to 'stiffen' the ride.
Good work Simon!
With all that new found grip out of corners I definitely will not be giving you ~any~ head start onto the front main straight at next years Powercruise... ;)
Grip ftw!
Like you gave me any head start this year! haha
I think by the time powercruise comes around I'll be running MT Streets on the rear to scare the GTR's :)
You are right, I'm guessing Simon isn't running bilsteins or a decent shock though, didn't he say he was running a jap coilover unit? Even the 'good' brands are still average from what I've heard. How does the tein hold up compared to a new bilstein? Not first hand information but people told me that there was no comparison, how true is that?
Edited by Rolls
Looking at the times Simon's car is doing then I dont think there is that much wrong with the Greddy Type S shocks he is running. An S15 did an easy 1:44 at PI the other day with Greddy Type R shocks, before its engine gave way. So again must be reasonable if doing those times so easily.
Simon's thread isnt really the place, but I think Tein make fair, good and very good gear...Off the shelf Bilstein are a good flexible product, that can be valved to suit pretty serious applications. Just like ECUs and tuning, if you are going to play with suspension best put your belief in the shop that has runs on the board with that type of setup with plenty of proven results
:) Well read your signature... 135mph?? Sheesh! You get NO head starts..! ;)
132.5 not 135 haha
You have no idea how emo I was after getting chopped by the GTR's all weekend because they were gassing second gear half way through the corner... I was lucky to get traction in 3rd in a straight line :domokun:
Edited by SimonR32
Yeh, so many S13/R32s etc all complain about not being able to get 180-200rwkws to the ground and these days I automatically assume its because they run "fully-sik" all sub frame bushes.
Ill just say here ive converted to s14 rear cradle in my 32 with alloy craddle bushes and this a has 5x the amount of grip and stabillity the car now has so in some cases alloy sub frame bushes will work i mean full alloy bushes though not the lil c looking ones.I was very impressed with the grib and stabillity it has bought back alot of grip
That was my original plan but lack of time and extra effort put me off... I may end up going that way one day if I feel the need!
What kind of subframe bushes/alignment were you using before the swap? and also how much extra NVH are you getting with the solid bushes?
but what did you convert from..
i mean does it have 5x the grip of an already good setup or was yoursetup all wrong in the first place...
That's what I was hinting at... If he has gone from Whiteline "maximum traction" setting to this and thinks he has got 5 times the amount of traction I think I will have to make the change :thumbsup:
Just dont tell too many people in Vic that simple bushes in the rear ends of S13/R32 is the way to go for great traction. I am posting vids of PI up this weekend. You will be amazed by the power down in 2nd gear with attitude on the car. Keen to see you vids...your times are mighty quick
I was fairly happy with the times considering it's a street car with no cage and full interior etc and probably the worst aero in the world haha. I'm going to purchase a Gopro Hero2 when I get back from my holiday :thumbsup:
Edited by SimonR32
Well looking at those fancy R32s, Series 6/7/8 RX7s and S14s etc running around in your Improved prod class, they are only doing 1:04s! And from memory all the big bangers in the top 10 at the WA Dutton Rally were generally only 62 sec mark
I think there would have been a 65 in it with a bit more practice but I was still tentative on the brakes after I went off backwards into turn 1 last time I was at the track.
The last lap of the weekend I was going to do a balls out lap with around 50 extra hp plus 500rpm to see just how that would go but alas it blew the cooler pipe off as soon as I got on the gas along the main straight haha :pirate:
Edited by SimonR32
  • 1 month later...
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
