last day of rego for the r33 before it got its new suspension tyres / radiator / stock intake.
should be back on the road in january. - new rego!
then z32 afm , power fc goes on / tune / dyno - hoping for a 250kw tune
Link removed by Moderators, PM sent.
i can now vouch for their toughness.
clutch required a bleed after that episode.
Edited by GoldZilla
https://www.sau.com.au/forums/topic/345801-skyrice/
  • Replies 48
Hey Keir, you probably won't get a really positive response to that in this section of the forum.
Personally, I don't think its some of your best work, we all get grief at some point driving imports, because of the "guilt by association" reputation they have. This is EXACTLY how it happens. I like a burnout as much as the next guy, but faark, in the street? Youtube? How original. Great piece of footage for Today Tonight's next "Import Driving Hoons" story.
I'll be honest with you, if you did that in my street; I'd tell you to piss off and take it to a track. If I saw you do it again, I'd be giving your rego to the police.
We all have a responsibility to think a little bit about this kind of thing, otherwise, the cars, and the lifestyle we love will be taken away by simpering, sooky, politicians looking for an easy vote. Then you'll be driving a bloody Camry wondering how it all went so wrong.
That said, hope the rebuild goes well, looking forward to seeing some pics of it ON A TRACK!
https://www.sau.com.au/forums/topic/345801-skyrice/#findComment-5569969
this was in the back quarter of an industrial area in the middle of the night in a dead end street. he spent 30 minutes trying to find the most out of the way place on location on a return test drive.. my mate couldnt help himself.
daleo - fair call i cant understand where your coming from. - it was reckless..
i actually wasnt driving. :whistling:
was the first night we got it boosting right.. and my mate decided he was keen to see if it could finally boost a burnout.
its actually from weeks ago i wasnt going to post it but thought it was amusing. :)
i shouldve gone with my first hunch and not posted this.. heh
Edited by PetroDola
https://www.sau.com.au/forums/topic/345801-skyrice/#findComment-5571727
This took on a bit of a life of its own eh?
I'm the first to admit to some monumentally stupid car behaviour in the past, some of the other posts give the impression they've never done a skid.
You won't get any more criticism from me.
Get going on that rebuild.
Cheers, Dale
https://www.sau.com.au/forums/topic/345801-skyrice/#findComment-5571761
Cheers, Dale
life of its own it did.. guess i shouldve put a bit more thought into posting that video.
didnt feel criticised dale, more enlightened to your mature perspective.
cheers. keir.
Edited by PetroDola
https://www.sau.com.au/forums/topic/345801-skyrice/#findComment-5571797
The fact that this is "in the back quarter of an industrial area in the middle of the night in a dead end street" is no excuse - it's still on the street and as has been said, it's videos and posts like these that bring a bad name to the whole car community, especially Skylines.
https://www.sau.com.au/forums/topic/345801-skyrice/#findComment-5571870
Guest
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
