Hi guys,
Looking at upgrading the diff in my R32 GTST. Has an RB25DET fitted & has seen better days... Viscous LSD is still working fine (for now) but diff is very noisy (suspect c/w & pinion or carriers) so figure while I'm there I may as well upgrade LSD. Daily-driver but may end up doing track-work soon.
Basically tossing up between a full GTR rear-end & an aftermarket LSD centre. Roughly same sort of price...
I am a mechanic by trade & specialise in auto-transmissions & diffs, etc so could easily enough fit the Nismo clutch-pack upgrade to the GTR diff.
I realise the GTR shafts are stronger but car is & will be only making around 300rwkw so probably overkill.
Has anyone even had problems with GTST shafts before at any power level?
The thing is GTR shafts are also heavier & for the sake of performance, etc I am trying to keep everything as light as possible.
I know the GTR runs alloy hubs so would this counter-act the extra weight of the shafts?
Any opinions on the best overall compromise would be great.
Cheers
  • Nope 3
  • 1 month later...
The driveshaft in GTS-Ts have been known to wear over time, especially with highly modified gts-ts
The most common problem is tailshaft backlash which can come in the form of noise/vibration from the rear in a different degrees.
When I had my recent service, my mechanic said that I have a bit of tailshaft backlash present - still can't pick it myself but its there none the less.
With this wear starting to happen with mine, and me only only making 235rwkw, I'd say it would be a good idea to upgrade the diff if your making 300rwkw +
GTR diff will be bullet proof. Get a recon'd second hand one and you'll be laughing.
James
I snapped a rear axle with 195rwkw. But I think that was no real indication of the strength of the axle. Know plenty of other GTST's with more power or harsher drivetrains that have been fine I think I was just unlucky.
have you considered a 1.5 way? A friend went from a locked diff to a 1.5 way in a 32 and was very happy with it. seemed very predictible and locked hard (Nismo 1.5 way I think it was)
There not terribly cheap to buy outright but he got his second hand at a decent price so if your lucky something like that could show up, or you might find something on import monster or a japanese spares site. I dont know much about the GTR Diff's but I can tell you for sure that the axles are thicker and stronger. But I didnt really think at 300rwkw you would be snapping axles (despite me snapping one with 100kw less)
I have a Nismo 2-way in my 32gtst and I love it, was a daily driver like that for over a year. It's not for everybody though and requires a slightly different driving style.
If you like scaring grannies, mothers and small children in carparks, as well as having a SUPER predictable diff, then go the 2-way :P
Pretty much as bubba has stated.
For a daily i personally would not get a tight mechanical diff. I put a regular old nismo 1.5 way in mine, and though it did the job for the track and skidpan duties the car got, it made me dislike the car as a streeter. Nothing wrong with the diff, i still have it in my s13 track car.
For a streeter i'd get a nismo pro 1.5 way and adjust the preload to soft for daily duties. Plus there is always redline friction modifier to make it a bit nicer as well.
As for breaking drive shafts; If you drag it with sticky tyres you will break a drive shaft at some point. Upgrade to the gtr centre and shafts if that is the case.
Edited by badhairdave
this but get the pro tt model and leave the preload in the middle.
mine has seen 300rwkw for 2 years and never missed a beat. it's not a hastle for daily driving at all
    • LOL.... a good amount of people (not all) on that continent seem to know everything and like to measure things in bananas, football fields, statue of liberties instead of the metric system lol.
    • I assume the modules are similar enough, so if you've had no issues I don't see why I would. I have tried to find a wiring diagram for the FPCM / fuel pump circuit, but I can't find it anywhere. Otherwise, I would just do some wire cutting and joining at the FPCM and give the 12 V supplied to the FPCM directly to the pump instead. If you know anyone that could help with wiring diagrams, I'd be very happy
    • If it dies, then bypass. The task isn't difficult. I have one running on a standard R32 FPCM. That's after nearly 20 years of it running an 040, which pull substantially more current than the Walbro. They're not the same module, but I'd hope it indicates that the R33 one should be man enough for the job. I think people kill them when putting proper sized pumps on them, not these little toy pumps we're talking about here.
    • Silicone spray won't hurt anything. And if it does, that's an opportunity to put some solid steel spherical bushings in, so you can really learn what suspension noise sounds like, If you're going to try it, just spray one bush at a time, so you can work out which one is actually noisy. My best guess is that if the noise started only since putting the coilovers in, then it is just noise being transmitted up through the top mounts of the struts, and not necessarily "new" noise from bushes. But it's almost impossible to know.
    • Are you saying the 34 is SUV height, and not that we're talking about an SUV here? (because if we're talking about an SUV, you don't fix them. You just replace them when something breaks. Not worth establishing sufficient emotional connection with an SUV to warrant doing any work on one). I wouldn't jack my car up on a short little loop of 10mm steel rod poking out through a hole in the bumper bar, front or rear end. I realise that we're probably not talking about that type of loop at the front, being the one under/behind the bar on a Skyline.... but even for that one, trying to jack up on what amounts to a thin piece of steel, designed purely for withstanding a horizontal tension force, not a vertical compressive force (and so would be prone to buckling/crushing) and, my most particular bitch about it - located RIGHT AT THE EXTREME FRONT OF THE CAR, applying a load up through the radiator support panel, etc, with almost the entire mass of the car cantilevered between there and the rear wheels? Nope. Not doing that. Not on the regular. That structure out there in front of the front crossmember is not designed to carry load in the vertical direction. Not really designed to carry any load at all, really. The chassis rail that the tow point is connected to would be fine loaded in tension, as per towing. Not intended to carry the mass of the whole car, especially loaded all on one rail, with twisting and all sorts of shitty load distribution going on. No, I will happily drive up on some pieces of wood, thanks. That can only happen on driven wheels, and they are at the other end of the car, and this problem does not exist at that end of the car. And even then, I have been known to drive up on at least 1x piece of 2x8 each side at the rear, simply to reduce the amount of jack pumping necessary to get the car up high enough for the jack stands. What really really shits me about Skylines is the lack of decent places for chassis stands at either end of the car. You'd think they'd be designed into the crossmembers.
