wtf thats the most stupid thing ive ever read. thats derogatory in itself. associating the word pig with cops by default is derogatory. didnt you do well in english class?
im sure the word pig comes up often when not being used to refer to cops.
https://www.sau.com.au/forums/topic/346495-sau-30/page/16/#findComment-5605801
99% of the time on SAU, they are referring to cops.... in the real world probably not so much lol
And yes I did great in English thanks for asking. Don't get all narky at me, I didn't do it, I'm just explaining why.
https://www.sau.com.au/forums/topic/346495-sau-30/page/16/#findComment-5605846
The only time it gets used "correctly" seems to be in the Wasteland when boz talks about animal fetish and similar things :D
But as its an automotive forum, plenty come to rant about "the cops", you just never realise as its autochanged :)
Its a good filter, rarely is anyone talking about a "pig" in the animal sense
https://www.sau.com.au/forums/topic/346495-sau-30/page/16/#findComment-5605954
yeah look, I remember putting that filter in cos of all the people who tend to post threads to rant after being caught doin stupid shit by the cops.
you don't like it, you can GTFO. or stop talking about pigs? maybe expand your vocabulary to swines, hogs, boars, women from frankston, etc.
https://www.sau.com.au/forums/topic/346495-sau-30/page/16/#findComment-5606315
Sometimes, as in how many times have it been used/not worked on this forum?
Link to the times. IF you can show me it 5 times i'll remove it.
Fact is, it rarely - rarely - gets used in that fashion on this board.
https://www.sau.com.au/forums/topic/346495-sau-30/page/16/#findComment-5606494
i just discovered we have the cyantic skin there now so i'm giving it a bit of a try at the moment. i still don't like it as much as the old dark skin (and am undecided if i like it more than the standard skin).
as the pig subject, it only affects me because i often say something runs like a pig or was a pig to drive
https://www.sau.com.au/forums/topic/346495-sau-30/page/16/#findComment-5606855
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
