The car you drive is unimportant and you know that - its SAU, the community.
Not just skylines!
Plus the classes for trophies (track day & S'n'S) and so on are not restricted just to skylines. Any model can win :)
SAU Nationals now on Facebook - Add as a friend for stream updates as they are available :D
Username: Skylines Australia Nationals
http://www.facebook.com/settings/?tab=privacy#!/profile.php?id=100002163814442
wheres your accomodation being booked 'moid?
if one of the venues is the benalla leisure park, better make sure the owner doesnt get his knickers in a twist because the average age is below 60, doesnt drive around australia with a caravan in tow, and might make noise past 7:30pm
just sayin......me and a few mates had a run in over the weekend with him
im sure if he gets enough money coming in, he'll buy some thicker earplugs just for the weekend
Accom will be sorted/managed by a 3rd party.
There will be different prices based on whatever people want.
Details will be up - its in Shepparton and there are 10-20 places to choose from ;)
People with trailers etc are also no issue.
We are up there 4-5 times a year with SAU-Vic, the local accommodation places have no issue as long as people show respect.
Also - MORE MORE MORE adding to Facebook people.
200 people in 4 days isn't bad - but surely there is more.
It will be the primary way info will be sent out. It'll also be put onto the forum etc, however instant updates are easier ;)
A mate and i are thinking of making the trip down from Sydney, Any other Sydney boys or girls willing to make the drive down from sydney with us ?
Considering driving down from Sydney too with a mate. Should be a great weekend..
Arrival/check-in etc.
Given accomm for most places is not avail until 12pm-2pm - people simply arrive/gather.
If you convoy'd and left at like 6am, you'd be there 2-3pm no worried in perfect time.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
