Hi, I know there's a 50 page stickied tyres thread, but unfortunately I didn't have 10 hours free time to trawl.
I am looking for a decent set of tyres for an R34 GTR on stock rims. Wanted something of a harder compound so I don't need to change them every year - willing to give up some grip for this. Good in wet as well. Used for spirited street driving - no drifting/track. Can anyone recommend something like this for under 2k all round?
I am based in Melbourne. What's a good place to get them?
Thanks
https://www.sau.com.au/forums/topic/346754-what-decent-tyres-to-get/
Thanks
You are just about asking the impossible, a Hard compound tyre, that has good grip in the wet and will handle 300rwkws in the wet for under $2k?
If you are changing tyres every 12 months I would be looking at your wheel alignment.
Toyo T1Rs have a stupidly soft compound, 595SS' are a pretty horrid tyre (they are cheap for a reason)
I would have a look at some continetials or the higher end comfort Bridgestones
- willing to give up some grip for this. . .
How much grip? >_<
What if you get 10 replies with 10 different recommendations?
Have you read tirerack.com feedback/tire reviews yet? Or shall I just add an extra opinion to the "10" and say that Potenza RE55 may now replace RE001? :P
Good place? Does your grand-dad/mum have a Seniors Card? If so, be nice to him/her and look up the Seniors booklet and check out where the 10%-off places are!
Sorry forgot to mention its 300 awkw.
Cool, will look into this.
yes 595ss are pretty horrid but they will last him forever and are cheap...
i ran them with 300rwkw and for the price they do pretty well... however i would only ever buy them for a daily or drift .
so what kinda treadwear are you happy with? and what size?
Advan AD08's should come in your price range, but wont last that long... same with Nitto NT05.
Bridgestone RE001's will probably suit your appication pretty well.
Falken FK452's are the best street tyres IMO. They're simply AWESOME in the wet.
I can supply them in 245/40R18 for $255 each. I can get Federal 595's cheaper but they're not that great on an ultra high performance car like a GTR. You really want the best when you have a GTR to make the most of it.
Cheers,
Brad
tyres4less.com.au
Sorry if I came across as picky.
Had a look through the Tire Rack site and Tire Reviews.co.uk, and they are both great sites.
Think I want these:
Michelin Pilot Sport PS2's
Tyre Comparison Chart
They kill everything else on Tire Rack for dry weather handling/ traction/ stability. I currently run Michelin Pilot Precedas (which I am very happy with), and these are a step up.
And trawling the net ppl have gone up to 40,000 kms on them before wearing out. I know tread wear is dependent on many variables, but I would be happy to get 15k out of them with 95% daily driving and 5% spirited street driving (I only do about 7k per year).
Price-wise, with the strong aussie dollar, ordering off Tire Rack plus shipping to Oz will set me back approx $1450 total, plus fitting, so I am very happy with that.
Tire Rack PS2s
What do you guys think?
Thanks for your help.
PS2 are good. You could probably get them locally for around $1500
For price /performance Sumitomo ZIII, literally half the price (on tirerack) of the PS2 for 95% of the performance. I use these, they are great with gradual loss of traction. You'll get at least 20,000km, I get ~40,000km. Locally I paid $1000 for a set of 4 fitted at Jaks(235/40/18).
The Conti "Extreme Contact DW" looks good from tirerack reviews for the price compared to PS2 also. If you are importing and only want ~20,000km you might as well get the Dunlop Direzza D1 star spec.
Edited by simpletool
+1 For 452's, very grippy and made in Japan.
If you look round you should also be able to find some Toyo Proxes T1Rs on clearence ATM ;)
Edited by Hank Scorpio
When you say that a particular tyre is "Horrid" you might want to specify that this is only your opinion because the Federal 595 is actually very popular and a lot of Skyline (and other high performance vehicle) owners swear by them.
Yes they are at the inexpensive end of the tyre scale but they certainly arent a cheap, crap tyre sold only on price... For a really good "bang for your buck tyre" you almost cant go wrong with the 595 - in my opinion.
i just got kuhmo ku31s allround for my gtr, currently on 330kws and they hold the power very well in wet and dry
unlike the federals ss i had on previously, and best of all i got them through tempe tyres in sydney for 800 delivered to
my front door (melb)
thats for 265x35x18
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
