Hi, did a search but not much came up.
What are the widest rims I can run on an R34 GTR? Also, where is the best place to get guards rolled/pumped to accommodate fat tyres?
What is the legality of this and really fat rims in Victoria?
Lastly, do I need to use identical rims on all 4 corners to not confuse ATTESA or can I stagger them?
Thanks.
https://www.sau.com.au/forums/topic/346825-widest-rims-for-r34-gtr/
All depends on if your going 18 or 19 inch. Also what size tyres you want to fit.
I know for a fact you can go quite wide.
With legality, I think if they stick out past the guards then you can get done for it.
On gtr's you must not stagger otherwise problems with Altessa as far as I know.
Biggest you would go without worrying about modifying guards would be 18x10.5 with a maximum offset of +12. if you were to go 19's with the same width and offset you may get some rubbing on the inner guards on full lock depending on tyre size and width.
  • Like 1
my wheels came off grant's r33 and are 18x10 +19. sat well on his car, if a teensy bit inside the guards. you can go bigger on r34.
also, atessa only shits brix if rolling diameters are diff f/r. you can stagger, but choose tyre profiles carefully. most cant be arsed with this, which is why they say run samesame all round
pics of same offset on 33r
http://www.skylinesaustralia.com/forums/index.php?app=core&module=attach&section=attach&attach_rel_module=post&attach_id=303399
http://www.skylinesaustralia.com/forums/index.php?app=core&module=attach&section=attach&attach_rel_module=post&attach_id=303401
  • Like 1
I had 18x10 +19 AVS Model T5 with 275/35, fit easily however there's slight rubbing on inner guards when going into driveway.
Then I had 18x10 BBS LM with 285/30 RE55s, swapped the coilovers and ran lower, no rubbing at all.
For R34 GTR, you can run what Jack recommends, or hell, buy some of his rims!
Niroj, I never ran tri spokes, bought off a dude who had in his 33 GTR.
  • Like 1
my bad
Jack's Sparco's look like awesome value for money, and would look hot on an R34 GTR
Cheers Shane... they are quite cheap since they're brand new...
I have too many sets of wheels to suit GT-R at the moment...6 to be exact....
Wheel whore??? I have a good excuse, I have 3 GT-R's....
Cheers, thanks for the replies.
Thinking of going the Volk TE37 Bronze 19 X 10.5" + 12, with Michelin Pilot Sport PS2's in 285 or 295/35R19 . Smallest offset I could find for that rim on NENGUN. Where else is good to buy TE37s locally? I tried Importmonster's aussie store but they only have the rim in massive offsets.
I just bought a set of 19 x 10.5 +11 for my 34R. Should be fitting them next week but I would not personally go any bigger.
Would love to see pics plz. Let me know if any rubbing - cuz if there is I may have to go down a size/width. Stock suspension?
Thanks.
Try hawthorn tyrepower. They have the best display of rims and can get you whatever you like considering they own a 35r and amuse 370z.
I will be purchasing soonish a set of Te37 SL's 19x10.5 +12 for my 34r.
Te37's with an aggresive offest just look mean on a 34r.
As Nathan said above, I was there yesterday and they have heaps of TE37's to check out.
I was only going to go 285/30/19 but does anyone know if the 295/30/19 will be ok on a 10.5 wheel +11?
my car has only been lowered 30mm but I am a little concerned that the tyre will rub?
Thanks
Dave
Thanks
Dave
Personally I would go the 285/30/19 instead of the 295's, they will more likely cause rubbing on full lock and the benefit of going 10mm wider on a street car is negligible as far as performance. Save your pennies or go a better quality tyre in 285 wide.
My 2c...
  • Like 1
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
