As far as i know most pple r doing the 6boost manifold n external gate but thats not what i want. Im keeping stock manifold, internally gated and low mount.
Go external on stock manifold better boost control
Personally I am yet to see any dyno sheet of a TD06-20G (be is TD06S or TD06L2) make +300rwkws on 98 pump fuel. I would love to see some, especially SR20 plots as those that I have found and compared to my RB20 plot have been found to be wanting....
And has anyone ran one of those internal gate housings? They look horrible for effeciency?
Give us a few weeks, over the break we will fit our KD TD06SL2-20G onto our drift car and well let everyone know how it goes. 20psi will probably be the absolute max though.
ahh what, not you too, now everybody is doin it..I dont wanna anymore :whistling:
how would this one go? http://www.ebay.com.au/itm/Kinugawa-Turbocharger-4-TD06SL2-25G-T3-V-Band-450P-/280775108722?pt=AU_Car_Parts_Accessories&hash=item415f802872
rated to 650hp, so should easily achieve 300rwkw on an rb25 with good boost control, being ext gate. however sounds like it will hit full boost between 4500-5000rpm on pump 98. would that sound about right?
Same as my T67-25g just named differently :)
Yes should go over 300rwkw and full boost before 4000rpm
just took my drifter for a quick run, just roughed in a tune so i could drive it and see how everything is.
this things gonna be mental, i cant beleive how hard it ramps up onto boost and the little screamer just cracking open, i took a quick video on my phone, cooler pipe popped off so i threw phone down to make sure i could make it up my driveway, ( u will understand when you see it)
excited to get it on the dyno
LOL, Ive have had my TD06-20G for 7 years. They were rocking horse shit in Aus when i put it on because of their "Truck turbo" reputation vs the swanky BB Garrets/HKS.
They do seem to be everywhere in plague proportions these days and that because the results obviously speak for themselves :) Still...be a man and go Trust rather then Kando :)
edit...if my car as stock I would go Kando...they are gaining a great reputation in their own right
Only the first few seconds are any good. I popped the cooler pipe off mid 2nd gear. This was with maybe 3/4 throttle.
I will try and get a better vid ince its up and running. This car hasnt been driven for 2 years. I got it as a shell and built it up over 4weeks in my spare time.
ah right, damn i get confused with all the different names these things have. would you know if that thing can fit on the stock manifold?
Hey hey im getting attacked by the kando virus today and now seriously considering a kando low mount(stock manifold) 280-300rwkw STREET turbo for my neo over the Hypergear, needs to be internal gate too so no stuffing around welding an external gate, basically looking for a 3076R/ SS1PU equivalent..if anyone can point me to the correct specced kando unit and dyno graph (so many numbers n specs), i will buy him a packet of chips..:winks
such a teaser vid...how much was that at?
i have no idea what rpm, boost or afr it was at, i know its rich and safe but my tacho doesnt work atm, i forgot to look at the boost gauge, too busy trying to keep it straight
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
