For the money I would rather get genuine nismo 740s. The Nismo 740s are meant to be very good to tune with, as good as stock and better than the Nismo 555s.
Do it once, do it right.
deatchwerks are meant to be very good as well from what Ive read
I'm all for cost saving on things like the turbo, if its built to spec then its built to spec.
But injectors I believe are a different ball game. I'd get the Nismo's, they are what they are meant to be. Purpose built to replace the RB/SR side feeds.
Why not try find a genuine used set?
Otherwise get a FReddy and china rail + bosch (my 2nd choice and FReddy + T67 seems to = WIN)
deatchwerks are built to spec and with a proper spray pattern, they bolt straight in and are highly regarded, from what I've read they are just as good as the nismos and there is no reason to doubt them.
old truck turbo.
i just killed my 1st set of tyres. On 9 psi this 20g has no problems laying 3rds, going much better now with the correct spark plugs, its a 2nd hand motor and i never checked the plugs when i fitted it.
i took a rolling 1st 2nd 3rd video but for some reason it didnt record sound
25. Stock with injectors and turbo. Very curious to see what power it will make. Planning to be at eastern creek drift day next thursday
So whats your current opinion on the 9psi its on? Comparable to what?
I used the tight ass method, cut the water line above the banjo fitting then braze over the hole with an oxy and bolt back on!
alternatively you could just run a hose straight from the water source at the inlet manifold to a fitting in water return on the block..
More things to go wrong man.. useless hoses melting and crap like that.
Just block em.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
