Scott, thanks, I do now understand the concept of an external gate setup, and hell no, I'm not going to have an open screamer and hence a massive fine and defect, it will have to plumb back onto my dump, and either collect the gases out from my stock manifold or turbo rear housing - I dunno which is easier /cheaper /more preferred..
Is it sad that I now dont want one of these turbos because everyone buying them is doing it as cheap as possible.
I am now waiting for all the threads/comments saying my car isnt performing like Simon-R32's car etc
modded the stock manifold to suit 44mm v-band ext gate, running either a tial mvr or turbosmart hyper gate
Did you keep the standard splitter inside the manifold when you modded it for external gate? If you didn't I would recommend that you ditch it, get a new one and weld gate to rear housing!
Guys asking about gates, I think Tial 44mm MVR off ebay for $400 is a bargain and you can't go wrong :thumbsup:
Make sure you have your labour aspect of things well sorted and know the implications of a screamer (if you opt to go that way) or how standout your setup will be to NSW highway patrol.
On a dedicated street car this is why the HG wins everytime no matter the cost.
Never fear, I'll chuck some cams and springs in my car this year and try for some more power to keep the pundits happy :whistling:
Ur a pretty sad bloke Zebra, not surprising seeing as u from ACT...pinch.gif
Will it please you if I go mount my Wastegate on my dump pipe?
oh no you didnt...
yeah MVR gate on ebay was the cheapast i saw $410 del (that seller is away till 8/1/12 btw) then next is $440 @ powertune.com.au
i got mine second hand.for $300 del.
BSA is doing the mod to the manifold for me, his pics are below of the one he did on his car and looks like the standard splitter is still in place :thumbsup:
The thing that worries me with gate on manifold is police/ pits if you get a sticker and need to go over pits to go back to standard turbo you need another manifold if it on housing pull off turbo bolt on stock turbo get a basic tune take over pits done easy as
LOL somehow I don't think you are quite knowledgeable enough to make a comment
Since you are so clever stripey horse, I will tell you why I dont like the idea of welding onto the stock manifold - luvpsi above said it for me..
If you have fresh studs that are <10,000kms do they snap just as easily?
Reason I ask is I took my manifold and turbo off twice with the same studs and had no issues, they were all under 10,000k though. Was running 18psi on a highflow so would have gotten bloody hot as well.
Edited by Rolls
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
