Pods need to be covered. Yeah artz yours does blend in also helps your running the crossover pipe. I had mine run down becide the plenum so everything was open. My BMW build will have a front facing plenum so gate is least of my troubles. Putting jez's kando to the test tomorrow it's drift day can't wait
Wakey wakey boys.
All Geared up ready to tow to eastern creek. I borrowed a mates go pro so there should be plenty of incar footage.
I got the tacho working now so atleast we can see rpm to boost response. Dont think the car will see much below 4000 though. Maybe in and around the pits.
I didnt get time to convert the speedo drive so there is still no vct. Should have that sorted before i get onto the dyno next with a 20psi tune. Then its straight to the drags to see what time and mph she can run.
If you can hide things then great. I must be lucky as my engine bay has looked like those pics since 2003 and never booked. So if your car externally is nothing flashy and your exhaust is quiet then there is surely a good chance you will never be asked to pop the bonnet
I have more or less gotten away with murder also when my cars have not been overly loud and have had respectable rims on them etc.
Cheap looking oversize rims and very loud exhausts will get u screwed regarless of how normal your car is. A well kept respectable car will go unnoticed in terms of them being total pricks. Then again it depends what your caught for too.
I love this thread. I wish I had another 6 so I can run a Kando... I think im better off with a stock position turbo on the SR though, good work to all the guys with nice Kandos on their RBs.
Zeeb I have an LS if you are looking, VT2 clubsport kitup with box etc.
Some of you have me on FB, youve seen my photos. Car is mostly done, not going back now :P SR all the way.
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
