Not convincing enough Scot! I think you have tried about 3 times to push me towards HG turbos, for god knows what reason I have no idea at all..
OK the reason why is because I honestly believe the kando does not suit your application. You have preached that you want bolt on and no fuss, and you have dictated a power goal with maximum response.
What I am doing is utilizing the knowledge and experience I posses to give you the best possible advice I believe I can. At this stage there is little to no evidence to support that the fabled 10cm 20g will meet or exceed Stao's efforts. I believe it could go either way.
The method that Stao uses to create the SS1PU involves a balance of the highest flowing turbine in the tightest possible high flowing housing he can match together. not the biggest with the smallest, but what is tested to be a good match in terms of the desired outcome. He has done exactly that with your 270kw fastest spool request, a turbo just for you. Call it the ronaldmcdonaldPU. Stao pushes the flow capacity of each to their limits to achieve the best result possible, which I think is GREAT for the application he intends, and I am TOTALLY for it.
When you consider the Kando 20g, it is also similarly described to the above. A tight housing, a smallish high flowing wheel, it should spool quick and make some good power. It obviously flows as it is working well for Simon (same turbine same housing to T67 vs SL2 if both 10cm). The big plan behind the Kando is the EXTERNAL GATE. The constraint envelope, while still present, is opened with an external gate - not for purposes of additional power, but additional operational headroom.
This added operational headroom makes little to no difference for the average user. Someone who will go do track days and boost around on his daily duties, which the HG will do and will do happily for minimal fuss. The Kando however is more likely to be happy doing 4th gear on a hot drift day or be punted for 30 minutes straight.
As much as I love the HG, this is what I do to tyres:
Do you do this to tyres? Do you get your brakes so hot they melt your tyres? lol.
This is my reason for liking the Kando and why I dont think the HG will suit me. I melt things. I am the one.
You on the other hand have made mention of wanting to track your car eventually, and that you like to drive it around. You currently have a stock dump pipe and turbo, and havent broken that yet. You have also asked how to bolt a v band to the stock dump, and if the wastegate plumbs to the dump and back into it again. All in all, get the f**king hypergear.
ive got myself a pair of these td06sl2-25g with 4in compressor covers these are rated for alot more hp with the 25g wheels and the bigger covers so im hoping these will get me over 500rwkw's on my 2j............opinions?
A friend used to have an R32 that ran a Trust 2.7L bottom end, OS Giken Sequential 6 speed with twin T67-25G 8cms. I think it made 610rwkws on a 100-104 style fuel like Sunoco. So suspect you will walk in 500rwkws. He used to run twin TD06-20Gs but wanted more so i grabbed one of the two TD06-20G 10cms that he removed when he upgraded... and still run that same turbo in my car oday.
Depending on what fuel you are running I think 20Gs may be the better option. ICE Performance's Nige ran twin TD06-20Gs oin his Supra and it made mega power. Maybe do a search for DAMN Supra
http://www.performanceforums.com/forums/showthread.php?67205808-574rwkw-DAMN-Supra-FS!
Not taking the mickey or taking shots. But I think the answer to that question is quite clear. He feels the HG turbos are the clear choice for your desired power and bolt on requirements. Seems pretty open and shut given that the Kando internal gate turebos have a very poor internal wastegate design.
Have a look at this pic...
http://www.ebay.com....#ht_2092wt_1139
See inside where the dump pipe bolts to, inside you see an opening? Thats where the wastegate gases have to vent into when the IG opens. So the air has to immediately turn 90 degrees, travel 1 inch then turn another 90deg and merge with all the gases coming out of the turbine and into your dump pipe. This causes lots of back pressure and poor flow which ultimately effects how well burnt gases exit the combustion chamber and how well they make power.
Now look at this arrangment, which is more typical of IG housings
http://www.ebay.com....#ht_1895wt_1270
When the IG flap opens the air is free to run into the dump pipe, be it split type or bellmouth type. The flow is travelling parallel with the turbine gases and generally offers very good performance.
That is the general thinking of why people are sayign avoid the IG Kando turbos as without even looking at dyno sheets etc you can see how compromised they are in the housings
Top post Roy, first comparison showing why the IG sucks, all I've heard until now was "it just sucks".
Cheers.
http://www.performan...w-DAMN-Supra-FS!
i havent seen that supra before .............nice find thanks for that hey :thanks: ..........if those turbo's i got are to big with the 4in cover and 25g wheels i can always buy the the smaller 3in cover and 20g wheels only be a little out lay to correct it
thats pretty much the same set up as im planning to run with the different sized cams but i got a hypertune inlet,link g4.id1000's and 6spd tremec magnum box
The the ICE Performance Supra was pretty well known car down here in Victoria for a while until Nigel and his business partner decided to move on. The car ran 10s, made good power on pump and did track days with 400odd rwkws where it was quick in the day. Was very fast considering the poor man used semi slicks he always used to run!!!
On funny fuel made some bigger numbers out of the same engine at Auto Salon. If Ash (R31Nismoid) reads this he may remember but I think it made somewhere early in the 600rwkws at Auto Salon one year but may have run NOS on the dyno. Was in HPI and a few other magazines years ago
The Greddy TD05 uses the same design, we never had any trouble with boost issues. At the time I thought it was a terrible design, but it performed fine. Went very well actually. Any reason the Kando versions would be worse off?
Whos we champ? I love the word we on forums, sounds good.
Seriously, if you have some feedback regarding these please divulge. Im sure everyone here would love to see proof that those housings are a good performer, it will save people PACKETS.
I for one dont believe in that housing, for basic principal, HOWEVER have seen plenty of genuine trust kits floating around with that housing on them.
Please share what you (we) know.
Sorry, my mate and I built an R32 track car together, used to have a Greddy TD05 on an RB25DET. Just normal to use 'we' whenever I refer to it now.
I'll see if I can grab the old dyno sheet from him tomorrow and I will upload. I'm not 100% sure of which model it was, it's a bit mouthy to refer to it as TD05xxxxxxxx all the time. But for those of you who can work it out, it maxed out at 325rwhp@18psi on 98 pump fuel. Full boost by about 4000rpm. As I said, we never had any boost control problems with it. Only issue it did have which could be related was at a track day, after a few hard laps the actuator arm blew off inside, so the wastegate was just flapping around inside and obviously it couldn't boost.
Was a prick to fix, so $300 later it had a complete brand new rear housing and all was good. Don't think we ever drove it again with that turbo though, a forged motor with a bigger turbo setup came along and the car went down that path.
*EDIT* just remembered the Greddy dump pipe that came with the kit was a terrible design as well, started as a 2.25" pipe to join to the turbo and then went to a 3" from there. Don't know if you care about that but thought I would mention it.
Edited by Hanaldo
I used to run a kkr 430 on my rb20, had a very similar exhaust housing design to the kando housing linked above. Looked horrible from a flow point of view, but said turbo made 220 rwkw with 20psi, never had any boost control issues. Keen to try a IG kando first, if I have boost control issues then ill sort out EG.
I wouldnt weld up and add the EWG tho, buy the proper V band rear housing, they now come in both 8cm and 10cm.
Other than the outlay of a second housing, a mild remake of the dump and a second tune I dont see any issue with giving the IG a shot first.
When I was originally interested in these I had a 6 and specifically asked Kando to make a 10cm T3 IWG housing, I still have the email thanking me for my feedback and confirming he will aim to bring that out ASAP. And now we have it.... But I dont have a 6, so moral is I was willing to do it twice and I still would be. I like IWG if they work and the constraints are limited.
HOWEVER Eiji was also MORE THAN HAPPY to lop the rear of the housing off for me so that the rear of it is totally exposed and it becomes a standard 5 bolt design (like a garrett IWG).
If somebody really wants to try this, the thing to do is email a request for a: TD06SL2-20g T3 10cm Internal wastegate with rear housing opened for use with 5 bolt or individual dump pipe, not single 3 bolt outlet and covered wastegate. wastegate to be uncovered.
Eiji CAN do this and it will resolve the little blocked WG issue we are worried about. But it doesnt mean the housing will be as good as his EWG item... But its worth a shot.
Interesting. There are so many variables...I am only basing my opinion on what I have seen from the Trust TD06 range of IG turbos. I have seen probably 4-5 people post graphs from results with IG Trust TD06-20G turbos or when the cars have been for sale. The IG turbos have always been laggier then the four setups I am familiar with that run STD RB20s with Trust external gate setups (my setup, Wheezy, Tim and Kris) and they always seem to be down >20rwkws.
Like I said many variables but the theme is they dont seem to be tuned to make more then 240rwkws and the external setups seem to be making 260-275rwks. So its either the tuners are mega conservative on all the IG setups or there is something different in their performance
Of course, the externals are larger with better flow so they will make more power in the top end. They should also have better midrange without having to put a heavy spring in the actuator.
    • Hey y'all! I'm curious about how y'all go about widebodying your cars. I noticed that when running a square setup, my front wheels are a bit more tucked in than my rear wheels. Not by much, maybe 5-10mm. This leads me to wonder - when I widebody, should I use narrower front flares and wider rear flares? I found a set of 40mm rear flares that I really like, and was thinking of pairing them with some 18mm front flares, but I don't want the car to look strange. How have others done this? Note, I'm in a sedan. Thanks!
    • And if it was anything other than an auto tranny part, it might be a problem. But seeing as all auto trannies belong in the recycling bin, it's fine.
    • I have an R32 Fenix rad. It is good.
    • All the schemas I can see, indicate your typical setup of ATF 'cooler' (read: heat exchanger) in the bottom radiator tank..ie; https://nissan.epc-data.com/stagea/wgnc34/5413-rb25det/engine/214/ ...but I can prattle on a bit here. These trannies have a thermistor in the sump ~ the TCU reads this and 1. bumps the line pressure up when the ATF is 'cold' and 2. prevents the TC lockup clutch from operating, until the ATF comes up to minimum operating temp (keeps the ATF 'churning' through the TC so it heats up quicker) -- trigger point is around 55C. In these conditions, the engine coolant temperature rises faster than the ATF temperature, and also helps heat the ATF up, which is why it's best to think of the in radiator tank setup as a heat exchanger ; the heat can flow in both directions... ...with these trannies, the 'hot' ATF comes out the front banjo bolt, flows through the cooler/heat exchanger, and returns to the box  via the rear banjo bolt. This gets a mention, due to the wildly different opinions wrt running auto trans fluid coolers ~ do you bypass the in radiator tank altogether, or put the cooler inline with the in radiator tank system...and then, do you put the additional cooler before of after the in radiator tank system?... ....fact is the nominal engine operating temp (roughly 75C), happens to be the ideal temperature for the ATF used in these trannies as well (no surprises there), so for the in radiator tank system to actually 'cool' the ATF, the ATF temp has to be hotter than that...lets say 100C -- you've got 25C of 'excess' heat, (slowly) pumping into the 75C coolant. This part of the equation changes drastically, when you've got 100C ATF flowing through an air cooled radiator ; you can move a lot more excess heat, faster ~ it is possible to cool the ATF 'too much' as it were...(climate matters a lot)... ...in an 'ideal' setup, what you're really trying to control here, is flash heating of the ATF, primarily produced by the TC interface. In a perfect world, wrt auto trans oil cooling, you want a dedicated trans cooler with builtin thermostatic valving - they exist. These should be run inline and before the in radiator tank system ~ when 'cold' the valving bypasses the fin stack, allowing the ATF to flow direct to the in radiator tank heat exchanger, so it works 'as intended' with helping heat the ATF up. When 'hot' (iirc it was 50C threshold), the valving shuts forcing the ATF through the cooler fin stack, and onto the in radiator tank heat exchanger...and you sort of think of it as a 'thermal conditioner' of sorts...ie; if you did cool your ATF down to 65C, the coolant will add a little heat, otherwise it works as intended... ...the 'hot' ATF coming from the front bango bolt, is instantiated from the TC when in use, so all/any flash heated oil, flows to the fluid-to-air cooler first, and because of the greater heat differential, you can get rid of this heat fast. Just how big (BTU/h) this cooler needs to be to effectively dissipate this TC flash heat, is the charm...too many variables to discuss here, but I just wanted to point out the nitty-gritty of automatic trans fluid coolers ~ they're a different beastie to what most ppl think of when considering an 'oil cooler'... /3.5cents
    • Been a busy but productive day. Axle and hubs acquired. All fitted up after a bit of modifying. Need to sort out wider mudguards and running light reflector covers but other than that the trailer is gooood to go !!
