OK more or less the same CFM of air (with a resultant HP) will have a higher EGT with the higher comp.
The TD05H-18g Jez tuned for me recently on a 9.5cr motor would start pinging once we hit 16ish psi. Pulling timing wasnt helping..... I have a feeling the 8cm IWG TD05H was just a shit balance when driving a big compressor on a high comp motor. It comes on boost very early and strong, just didnt want to take the boost.
It did make 207rwkw @ 15psi on a Mainline dyno, but hey we wanted more :whistling: It did not appear to be an issue with the way it was being tuned as I was on site watching timing and fuel trims being altered to combat the ping.
Was it super responsive with the high compression ratio of 9.5?
Jez can vouch, it is a very responsive setup.
Made 530nm @ 4200rpm and 207kw @ 6000rpm.
Im very curious to see what 10:1cr does, my motor is also a VCT model.
Haha come on man.
Still running besides the 150ml of oil in the sump after the sandwhich plate snapped off the block. New bearings and sat on limiter all day at wakefield.
I honestly havent checked the inj duty. My tial 44 arrived today so hoping to dyno it next week on 20+psi then off to the drags.
Nah sydney is horrid for E85, will be tuned on 98.
Thus my EGT concerns lol
Ah yes i see haha.
A mate and I used to own turbo commy V6s (yes flame on lol) and he had a stock ecotec with 9.2 compression and a GT3076 0.82 turbo. Car was fantastic made between 250-280rwkw depending on tunes and was super responsive.
Then he blew that engine and had a forged one built with 8.0 compression as per the advice of the guy building it. I said thats stupid but he trusted other guy more than me :(.
Car lost a lot of response and struggled to make 250rwkw with the turbo running hard.
I told him that he needed a GT35 and lots of boost to get the low compression engine in its element but he didnt want to loose more response. He ended up getting over it and selling it.
The higher the compression you can safely run to make your power level taking fuel into consideration is what I reckon is the best, especially for a street car.
Then I read about people putting turbos on stock M3 engines that are 11.5 compression with E85 with crazy results.
All this E85 talk :( , i'm getting tempted , i wonder what it costs for a 44gal? . Anyways , i picked up my turbo from the post office today :D i can't wait to get it all fitted , just a quick question about ext gate positioning , is it better to mount it off the exh housing or off the manifold??
I have not seen that many cars running E85 day to day. Those that I have seen running normally take forever to crank and idle like cops until warm etc if they dont foul plugs. Is there someting in the tuning of them or thats just the nature of the beast. Certainly I am yet to see an E85 powered car crank to life like on 98 and not splutter blowing sweet smelling fumes out the exhaust.
Not saying this is how it has to be...just that those I have seen have put me off it as there must be a trick to getting them nice for day to day
Mine starts identical on both E85 and 98 whether cold or hot. Although Trent from Status has tuned a heap of cars on E85 so has had a lot of experience with it. But the point is its definitely possible. My mum borrows my car and hasnt mentioned a thing lol
Right , i think i might make another thread on it soon :ph34r:
ok after a bit of a google search , E85 isn't the best choice for me , but the united 98 i was talking about a couple pages ago seems like the best compromise . link http://www.unitedpetroleum.com.au/fuels/premium-98
Edited by toffy
You can't get E85 in the UK, well you could at about 8 petrol stations then it was stopped.
There is an E5 I think though, it is the same nominal octane as the Shell 99 I use. Would E5 be better than a 99 RON (which has no ethanol)??? Both are 99RON.
you would have to find out what the RON rating is of E5, in Australia the E10 was/is a 91RON fuel unless advertised as a Premium 98 with Ethanol which is a 98RON..
I would go with what ever has the highest RON rating
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
