Now lets see them do a billet 16g and whack it on a TD05H rear end.
I find it strange now that we had always discussed the TD05H and 20g being a mismatch, but FP are using TD05H rears with their HTA compressors which are meant to outflow the 20g - thoughts?
I am considering buying an FP Green with the 44mm WG outlet on the evo 3 style exhaust housing. Then order an SR-MHI 6boob and go spastic
heres some piccys for you to have a gawk at... :woot:
how she sits..
I gave the intake pipe a scrub, then painted it black.. :ninja:
And the dumps, dumps into a twin HKS pipe, Scotty doesnt like my design, he wanted to build me a whole pipe but i reckon it will work alright,
if it doesnt I guess he will get his way .. :dry:
some things I have wondered should I have done differently...maybe 3.5 inch dump..and tempted to just stick a 4 inch intake pipe with pod as well...not sure if there is much to be gained though
Mines all ready to go..all I need is a silicon joiner for the turbo outlet (which is on its way) and a bung for an unwanted hole in my fuel rail...then put it all together properly..everything has been test fitted..
Scotty likes to lobster, I like to let him.....Screamer is close to the dump, maybe I should poke it through the bonnet :P
I need to plug my adaptronic in and attempt to rough tune it..but this can be done on my laptop..then hopefully I can fire it up this weekend :thumbsup:
3" is plenty with a venting gate, mine is only 3" and handles a lot of power. 4" intake isn't really needed, just make sure you have a good K&N 3" filter :thumbsup:
screamer looks pretty close to the dump, might just be the angle of the photo tho.
And? Doesn't really matter :)
Finger crossed for good results ARTZ, E85 or BP98? Who is tuning?
Also don't skimp on the graphs, we want boost, torque, afr and power :banana:
Edited by SimonR32
^^^LOL you build it on a poor man with kids budget and get back to me on that....
Yeah i forget the gate venting seperatly..should be fine
E85 or BP98 is the only choice I have to make actually...cant make up my mind on that..both a are plentiful but I do like to go for long drives..
Plus if I tune for 98 I still have something to look forward to later..But yeah, really undecided still..
Trents gunna tune it for me..
Don't u have a data Logit thing? Get Trent to do tunes for both e85 and bp98!!
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
