Hoping for a extra power everywhere above 4000rpm and maybe a tad extra down low :)
Do you have access to a data logger for before runs? If you want I can send over a simple GPS logger so you can map gs and speed so that you can get a feel for in gear acceleration and response. Something a dyno wont pick up
I have read a few people say that Nistune are decent enough but have their limitations. Is there a performance reason behind the change to Vipec from Nistune or just a question of more functionality?
I'm waiting on battery to see how he goes with the billet love... but it may be an option down the road!
Or see the difference a better flowing turbine will make :whistling:
I have trackaroo that tracks speed via gps but I find that the 1hz GPS updating of the phone is a bit of a fail so even if there was a difference you wouldn't be able to tell... Regardless I doubt seat of pants feel will change much, it'll go from shitting yourself to still shitting yourself haha
I'll try and get back down the 1/4 for the black top dyno run but I have faith the hubber should show the differences.
There is nothing at all wrong with the Nistune, it's more getting itchy feet. I would prefer the AFM gone as it's the last link in the blown cooler pipe chain saga. The addition of heaps more funcitons (proper VCT control, boost control and many other functions) is what tipped it over the edge. But mainly just ditching the AFM :)
I would love to give the bigger turbine wheel a go... The reason I gave up on the idea is because I knew that even if the result was better, I would still have to change back to the original turbo and just way too much effort (I'm lazy)
Completely understand. I just need an oil pump and somewhere that will do reasonably priced inlet flanges and I could find out about turbos myself soon enough :)
Re data logger. I have a little QStarz 10hz logger for when I am in hire cars and other peoples cars that if you think it will give acceleration etc you can borrow
Where did you get it from? I've been looking but can't find one jew cheap :)
Been looking at simonR32's pic's & I know centre mounting flange is different but housing size?
Is mine a 10 cm rear, as no marking's on housing?
Simon's
Mine
Edited by 32TAXI
I got mine from racerecall.com . It does the job, but I don't think it is as good as a Driftbox etc but then again is cheaper so performs the basic job I ask of it.
Whats the idea behind logging hire cars?
Well when you are hiring them and flogging them around the track when you are on holidays :) LOL, that how I know what a Swift can do around the combined GP Circuit-Nordschleife etc etc :)
Simon's
Mine
My rear housing is v-band to the centre cartridge while yours is bolted.... I think that is the difference! Looks like that is the difference between 8cm and 10cm by browsing ebay. What did you order?
Looks like you're almost ready for a tune?
Edited by SimonR32
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
