kinugawa 20g td06 l2 10cm
std manifold with tial 44mm gate
GReddy plenum copy
trust fmic
Power fc
deatschwerks 740cc side feed
z32 afm in cooler pipe
044 in tank
split fires and strait pipes
Caltex E85 305kw atw on 22 psi (minimal timing,Trent reckons had another 15-20 kw in her, but its more than enough for slider)
best fun ive ever had in a car
hahah
i dont have temp reading for intake charge Roy, but the hot side inter cooler piping was very hot to touch. The cooler must be a pretty old type, that im guessing is discontinued. I havnt seen another one like it, and came on the car when i bought it. Who knows could be a fake. Just has large Trust logo on the face of it. It seem to do a good job as the outlet charge pipes were much cooler than the inlet side.
Cool. Being hot to touch isnt a great indicator as a session at EC with std turbo had the hot side of my HKS cooler damn hot. But inlet temps were still 25deg C within ambient...so the inlet temp air temp is the real measure of whether you are cooking the air too much. Rule of thumb is an extra 10 deg C inlet temp is 1% power loss
Nah i got the V band clamp, thats what is on the turbo and im trying to bolt on the one on the ebay link. But i knew it was not going to fit like you said Simon i thought id poke around and look just in case i was missing something. Now Eiji is saying send him pics of what i was sent as i sent him the pics in this thread saying it doesnt fit. So maybe something was missing in the post to join it together somehow?
But it still looks impossible to fit so i have no idea what he is going to say lol
yeah with the 06ll2-20g on the rb25 the egt is getting too hot on 98 as the rear is really too small to for rb25 even with the 10cm. The e85 cheats and allows you to stretch it legs abit.
Eiji replied after he saw the pics and said "There are 3 x lock plates and 6 x bolt for this housing to fit TD06SL2 core. All you need to do is bolt it up to the stock core and lock it directly."
Am i crazy? I really dont get what he means? Beside the bolt on core this is all i got with it:
It looks like it comes with a v band converter ring. Without seeing it in person it looks like the ring is held in place by hte normal 3 bolts / plates then allows the vclamp to attach the cartridge.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
