I'll double check, pretty sure it was the 25g. Still seems fair responsive tho. With the cams it has a really doughy bottom end anyway and then comes on hard in the mid range.
I'll get some more details.
**edit**
*i was wrong, just confirmed it is a 20g, that's probably why it's so responsive.
I just ordered new 1200cc squirters and one of the new Walbro 416l/h in tank pump so I'll get a retune in a few weeks
Probably won't make any extra power but just will be a bit safer on injectors... Might try for 575hp so it's more than my old GTR haha
Fitted a Kamak T67-25g to my 260,000km old, internally stock 1J powered JZX90, Turbosmart 48mm progate, china manifold :(, 440cc injector and walbro pump - on the dyno today ..... its auto with a big stally, so am not expecting record breaking numbers.... will keep u updated
ah k. what brand 1200s r u gonna run?
powertune are doing 1200s drop in for the SR, supplied and fitted for $660. pretty tempting for me too, but im not sure what brand they are (fear they might be highflows of some sort).
They are high flows. They come from FiveO. They use a stock size I jector and flow then out to 1200cc. You can buy them a lot cheaper on US EBay but I still wouldn't use them. Fuel set up is something you don't want to skimp on!
Deatschwerks, same as I currently have. Straight drop in replacments for my current 750cc. They are fairly cheap as well at just over $600 delivered
In saying that does anyone want to buy my old ones (750cc low impedance GTR direct replacements)? Send me a PM
Edited by SimonR32
they are known quality though, so i wont fuss over how their made.
realistically it comes down to the process done to create them. if they have the pintle cap removed or have been drilled out then yeah.... dodgey...
but highflow can also mean internals removed and replacement parts put in. maybe the high cost of making side feed injectors is in manufacturing the bodies ETC... and you can cheaply replace the internal parts of an existing injector to create a good one (rebuild style highflow).
Im not saying this is or isnt the case... im just saying based on their track record of proven results Im willing to give them benefit of the doubt.
dumb question time but I'm sick of reading back, did 50 odd pages and don't have a clear answer.
unopened 20.
tdo6 L2 20G 8cm for around 260rwkw?will probably be getting cams at the same time. with a pfc and z32.
on same note, which sub 1k manifold?
Edited by Frenchie1001
    • You can’t see much on the other side as the lcd is there I don’t think it’s the same as the m33 beside it as the markings on top is not the same was hoping someone had a good quality photo or if they just happened to have the unit in hand, quickly take the cover off and take a photo to clearly show the marking on top to identify the diode   the unit is currently with an electronics repair shop so I can’t take another photo at the moment hopefully they are smart enough to know if it’s a zener diode or not
    • I'd be very surprised if you can buy new OEM mats. But if you can, I want some too!  Do you have links to the variations you found? Also, where are you located? I found that Nengun is happy to list items to purchase but when you do buy them you'll get an email that it's actually discontinued. As far as I know the variations in floor mats are different colour schemes as well as automatic and manual having a slightly different shape. The automatic ones fit into a manual car without issues, but I think you'd have trouble fitting the other way around. I have photos that show the shape difference if you care. FWIW I bought sets of used floor mats in decent condition at yahoo auctions.
    • Hi 🙋‍♂️. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? 😃  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this 🙏
    • Hi, Marek here 🙋‍♂️. I finally fulfilled my longtime dream - recently bought Stagea and now waiting for it to arrive in Poland. There's only few of these in my country, and one of the owners  recommended mi this forum as a source of all the info i'd need since now i own one  so here i am.
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
