Lol better get cracking then mate, what are you working on atm? the stag?
Nah, my brothers germini for last 3 months, but yeh stageas on the cards as soon as i get back from qld
jambo, i can't handle it being so slow anymore, just going to see how stao pans out with stock manifold, or a Brea sidemount
it is, as cops here are f**ked, need to be able to cover setup with acl heatshield to make it look as stocky as possible...
cheers
darren
First time in this whole build things went smoothly! Will let the graphs talk for themselves, but it made everything I wanted.
500Nm Torque - Check.
>200rwkw at 4000RPM - Check.
Full boost before 4000RPM - Check.
350rwkw - Close enough!
Big thanks to Trent for putting the awesome tune and Scotty for the fab work.
post-32498-0-45174500-1346679751_thumb.jpg post-32498-0-27958600-1346679882_thumb.jpg
The turbo upgrades and dyno results thread. Just so it is all in the one spot here it is:
R32 GTST
Stock RB25DET
Kando T67 10cm
Tial 44mm Wastegate
6Boost exhaust manifold
3" exhaust with single muffler
Random FMIC
Freddy Plenum
Bosch ID1000 injectors
Turbosmart FPR800
Walbro 400lph E85 compatible running E85
Splitfire coilpacks
Odd that mine makes quite a bit more torque in the midrannge (550nm from memory).other than that the t67 is almost identical to the td06 until about 6300, where mine falls over the t67 just keeps pulling hard..
Race? :P
I'd put that down to two things, your running 3psi more boost on that run, however you have more torque at 5K than me on 17.5psi as well. My money is on the forward facing plenum sucking some of the torque. Love how flat mine is though :)
Come to DECA this weekend and we can race :yes:
I put together a comparison chart when I was choosing my turbo.. just added Artz's and mine to it and here is how it looks. Artz's car looks like a much better setup for the street and I am a little jealous.. Hopefully I forget all about it when I have that extra 1000rpm coming down the straight at PI
Yeah t67 definitely looks more balanced..that extra downlow torque I have will only equate to wheelspin anyway then drop off while your still pulling hard...
I wanna t67 now. :(
Is there any deca spots left..heading up to Goulburn I think, maybe I could make a pitstop. Would only be on pulp though..cbf dragging all that e85 along.
It is currently full with 1 reserve taken (at least that was the case when the list was updated). I would be surprised if no one pulls out though. talk about wheel spin... with my bald 235 semis traction is a thing of the past
    • When you crank your car, and hit it with a timing light, can you see a steady crank timing?
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
    • yeah I was shocked when I checked my spare OEM on and as below that's how they come from Nissan. (side interesting note new NEO gearbox and replacement park lack the brass bush on the tips and its just all alloy) unsure about damage to the box currently back at 1110 to be pulled down/inspected and selector fork replaced as he built it previously and given the never before seen failure on his billet forks he is replacing it under warranty. He said he has used always OEM the keyway tab without issue for years so it could be an unlucky coincidence. I did talk to him about the sharp corners and stress concentration too. Re: hard shifts i got 7+ years out of the OEM one and the fork itself failed not the keyway. so could be bad luck as I said or an age thing + heat cycles in box and during fabrication of billet?
