3540 shaft snapped in half and the Kando cost less than just a core for the garrett.
essencially the same engine apart from new injectors, rochester 1000's and a the T67, it is spooling up heaps earlier than the 3540, around 1000-1500 rpm earlier which makes me think its the housing.
thats quite early but i think the 8cm would be even earlier.
take a few photos of the rear housing, i am fairly confident i can tell the difference. Take pics from around the flange area.
im fairly certain that a 10cm housing has more of a taper on the exit side of the T3 flange than it does on the CHRA side, whereas an 8cm has the same amount of taper from the flange on both sides and the snail shell is a little thinner.
This is my observation but im not honestly sure this is correct!
The genuine garrett .82 will be better suited. The .73 (10cm) kando housing is a tiny thing.
There are also better options available for that sort of power when talking 'responsive' and 400kw on a dirty thirty. Bare in mind a 35R is similar in size to a precision 6262.
A bush bearing PT can be had for roughly 1k delivered, and would be a hands down winner if you went for the T4 TS option. Single gate to keep costs low will still work a treat.
Finally here is a couple of pics of my turbo housing, i think it is a 10cm but it is just too small for my 25/26 with cams. We ended up getting 275RWKW out of it at 20psi on BP ultimate. It spools up to full song at 3500 and starts to drop off around 6000. It is very good to drive but we were pretty disappointed at the power output.
Simon, i suggest waiting to see how i go before getting the T67.
Worst pictures ever haha But I think it's a 10cm by the looks
In that case I can almost guarantee you something is wrong with your set up and not the turbo... These things don't drop off at high revs, we went well past 8000rpm with mine and power was still going north.
You are about 50rwkw down on where you should be... Got a graph?
Looking for a Kando for my 26/30. Has anyone got any thoughts on this? Basically a 3582r with .73 rear housing. Want to make a responsive 400 rwkw http://item.mobileweb.ebay.com.au/viewitem?itemId=120892863434
Hey Simon, I got a Kando TD06H-25g with the biggest houseing they make on my neo 25/30. It's not tuned above 5000rpm cos I need to replace my wastegate ( I'm not doing it untill my new 4wd arrives). To compare I had a Hypergear Gt3576 that made about 370rwhp on Ultimate 98 on Hyperdrive's dyno (In WA). With my rev limit set at 4500rpm I think I could safely say that the new kando turbo is massivly more powerful and massively more responsive.
I have herd of people running T67's on 3L's but I honestly reckon that it would be happier with the slightly bigger TD06H-25G.
But that all being said my car isn't fully tuned so I ahve no idea when it will stop making power.
i know nothing about the PT turbos.. just did some reading up on them.. looks to be the goods! might go with a 6262 i reckon
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
