Hi i need a new turbo asap and dont really have time to read through all these pages but basically does any of the TD06 turbos bolt to the stock R33 dump pipe? I noticed on Kandos ebaystore they had one that does seem to, it says it uses a stage 3 turbine does anyone have that turbo or know anything about it? I'm really only wanting 250ish rwkw with good responce and was considering a hypergear hi flow as i have a op6 housing sitting around but i just discovered this thread so am now confused which way to go, please help.
The kando highflow is not tried and tested yet, but is the only one in their range which will bolt up.
Your best bet is to send your shagged turbo to hypergear and get someone that many people have bought and know its good.
Bear in mind you cant just slap the thing on and wham get 250kw. You will need an ecu and the rest of the supporting mods.
Correct. A TD06SL2 20G is the weapon of choice if you want to go that way. It has been done and 260 was easily hit on 98 by 2 members... 300 when running E85 with supporting mods.
Bear in mind that requires an external wastegate also, which will need to be plumbed off either the exhaust manifold or exhaust housing. Despite the turbo being $700 odd you should budget up to $2,000.
In light of the above 250kw is arguably better attained from a <$1,000 hypergear 2IU 'standard highflow'. Have a read of the HG thread and you will find user reviews from people who have put them on near stock cars to people who are using them in track cars, good reliable option which will bolt straight back onto the car without further modification (other than EFI type supporting mods as mentioned prior).
Please read the many threads the forum has, you will be able to form your own opinion on where you want to go from there.
I second this....
Yes, it is a hybrid TD06SL2 with his billet 71 and 74mm wheels.
Again you still need to budget at least 2k to have it on the motor, and the above 300 supporting mods are arguably a lot more difficult than the those for 250 (need to move to E85, external gate, so on and so forth).
I know people who have done ~300kw @ hubs from stock EVO 9 turbos as well, as well as EVO3 16Gs with the bigger comp and turbine housings. We are going the non-EVO fit EVO3 spec 16G with 8cm housing so I'm picking we'll be able to make some decent power. The car only has a 2.5bar sensor so we can't get too carried away with boost, but I am sure we'll still get OK results :)
tractor SR's are a long way from 4g63's though.
Absolutely, we're not expecting magic. The old PE1420 delivered all that was needed of it - so as long as the 16G at least matches it's flow (no doubt it won't match it's response) it will be considered a success. Turbo is ordered, hoping it will be here next week :)
Don't break my heart :(
WOO HOO!!
LOL well lining them up might be possible soon, the new bearing carrier for my clutch finally arrived so im getting BUSY.
Regarding cancelling out we're both guilty so don't start :rolleyes:
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
