hmmm sat phone lol. feeek ah well no use to me...
de mister thas what i thought by why 2?
also i have a 6 stacker FACTORY NISSAN mini disc player for anyone who wants it. it was in my centre console taking up space!!!
Rear demister and some cars have element at bottom of front windscreen in case wipers are frozen and stuck to screen.
No dude, WINDSCREEN de mister, not a second button for the rear de mister.
As Kiwi said above (now why didn't I make it that clear to start with :/ )
ohhhhh frikin cool...
also another pic. last one i swear...
i know that this one does, that lil button that says auto... it automatically folds my side view mirrors in when i lock my car, and opens up when i start it
is this a standard feature?
Thats actually to point your side mirrors at the rear tyres when you put it in reverse. The side mirrors folding in is an alarm feature, it utilises/integrates with the cars inbuilt ability to fold in the side mirrors. The button for that is on the left of the steering wheel.
Dunc, you rock haha just pushed it and chucked the car in reverse! thats awesome!!!!
yea have no idea what that box is. im just going to leave it there... any takers on the mini disc player? i mean i dont use it and i dont know who would, but im sure theres some OEM OPTION freaks out there?
that third switch on the left is to turn on the 'cold pack' which consists of a heater element under the front wipers, and also heated side mirrors. the mirrors should have been changed for compliance, so hopefully they neglected to do that for yours.
heated mirrors FTW :)
everyones right about the windscreen demister. if you look on the outside part of your windshield there are some orange lines. it was for japan incase the extremely cold winters made your wiper blades get stuck to the windscreen
edit: iaiaiaiaiain bet me.
Edited by AaronNM35
Minidisc you say. . . I have so many minidiscs from my DJ days. .
I could be interested.. any pics where exactly did it connect to. . or was it in the main unit.
Jules
zei201 - thanks for the info, everything was left on the car as is from japan, complaiance didnt get thier way with this one
Paramour - im currently capped on the net.. f**kin ghey haha. but it goes in to your centre console!!! will get pics up after the 5th
Hmm, is there a function on the remote where we can fold in the mirrors after you've left the car? I know with my grandis I can by double clicking the lock button on the remote...
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
