woah thats crazy i feel for truckies as 8 times out of 10 they are not in the wrong when accidents occur. people need to realize how much weight these things carry and if you stop right in front of it you have the best bit of 70 tonnes running you over. not much is going to be left of anything after that bull dozers you.
I recently drove to Melbourne to pick up my new GTR and I saw a lot of crazy driving like this. I was surprised at how many people were driving in emergency lanes like in the video.
4.30 why should she back up she was there first, just saying.
no sympathy for truck drivers im sorry the shit i see them do is 11bty times worse than what this vid shows. Good to see the truck drivers have the same amount of curtousy for each other as they do no car drivers - none.
Coz she was on the wrong side of the road blocking oncoming traffic.
I drive througfh there quite often in my truck, you'd be surprised how many people do this. At least they have the courtesy to get out of the way....
I see this type of idiocy every day, you learn to accept it and not worth the trouble most of the time...
Cab drivers are the best though, especially when someone puts their hand up on the footpath, cabbie comes in from the right lane pit stop styles!!!! Have come close to taking a few out over the years....
Yeah i know.
I had been waiting to pull out for about 15 mins that 10 other cars and trucks behind me as well got really mad and pulled out.
i know its gonna sound like bs but honestly didnt see the other truck tailgating the one turning.
But what the hell its past now and i learned from seeing it on the internet that i need to chill and relax and wait for the right moment or you get your stupid acts posted so everyone can see.
    • Get an inspection camera up there.
    • Yeah, but look at the margin in viscosity between the 40 and the 60 at 125°C. It is not very large. It is the difference between 7 and 11 cP. Compare that to the viscosity at only 90°C. The viscosity axis is logarithmic. The numbers at 90 are ~15 and ~35. That is about half for the 40 wt oil and <half for the 60. You give up viscosity EXPONENTIALLY as temperature rises. Literally. That is why I declare thicker oil to be a bandaid, and a brittle one at that. Keep the oil temperature under about 110°C and you should be better off.   Having said all of that, which remains true as a general principle, if you have indeed lost enough oil from the sump that the pump was seeing slightly aerated oil, then all bets are off. That would of course cause oil pressure to collapse. And 35 psi is a collapse given what you were doing to the engine. Especially if the oil was that hot and viscosity had also collapsed. And I would put money on rod or main bearings being the source of the any noise that registered as knock. Hydraulic lifters should be able to cope with the hotter oil and lower pressure enough to prvent too much high frequency noise, although I am willing to admit it could be the source.
    • Thanks for the reply mate. Well I really hope its a hose then not engine out job
    • But.... the reason I want to run a 60 weight is so at 125C it has the same viscosity as a 40 weight at 100C. That's the whole reason. If the viscosity changes that much to drop oil pressure from 73psi to 36psi then that's another reason I should be running an oil that mimics the 40 weight at 100C. I have datalogs from the dyno with the oil pressure hitting 73psi at full throttle/high RPM. At the dyno the oil temp was around 100-105C. The pump has a 70psi internal relief spring. It will never go/can't go above 70psi. The GM recommendation of 6psi per 1000rpm is well under that... The oil sensor for logging in LS's is at the valley plate at the back of  the block/rear of where the heads are near the firewall. It's also where the knock sensors are which are notable for 'false knock'. I'm hoping I just didn't have enough oil up top causing some chatter instead of rods being sad (big hopium/copium I know) LS's definitely heat up the oil more than RB's do, the stock vettes for example will hit 300F(150C) in a lap or two and happily track for years and years. This is the same oil cooler that I had when I was in RB land, being the Setrab 25 row oil cooler HEL thing. I did think about putting a fan in there to pull air out more, though I don't know if that will actually help in huge load situations with lots of speed. I think when I had the auto cooler. The leak is where the block runs to the oil cooler lines, the OEM/Dash oil pressure sender is connected at that junction and is what broke. I'm actually quite curious to see how much oil in total capacity is actually left in the engine. As it currently stands I'm waiting on that bush to adapt the sender to it. The sump is still full (?) of oil and the lines and accusump have been drained, but the filter and block are off. I suspect there's maybe less than 1/2 the total capacity there should be in there. I have noticed in the past that topping up oil has improved oil pressure, as reported by the dash sensor. This is all extremely sketchy hence wanting to get it sorted out lol.
