Hi guys I just got my R33 going 2 day it was a bit of a project as i bought the car in bits and pieces and to find i have no air flow meter.... just wanted to know if there is a difference between the S1 and the S2.... I have a RB30 one off of a VL and the plug is not the same. any help would be really good and if anyone knows of any that would be better.
Edited by Charlie4401
https://www.sau.com.au/forums/topic/348569-air-flow-meter/
I've got a s1 AFM for sale currently (perfect working condition) if you need to purchase one. I'm in ACT so it will need to be shipped, but can mail it off asap if you would like. $50+ postage, can mail it off tomorrow.
https://www.sau.com.au/forums/topic/348569-air-flow-meter/#findComment-5604094
Hello ...
You need the R33 SPEC1 AFM!
The S2 AFM has 3 PINS and has also a different calibration curve.
(Actually the S2 AFM is similar to the R34 AFM)
I don't know if the RB20 uses the same AFM as RB25 ...
I have attached a picture from my S2.
Cheers,
Andrew
https://www.sau.com.au/forums/topic/348569-air-flow-meter/#findComment-5604324
