ABS has saved me loads of times on the street esp in the wet.
Really good safety feature when breaking as they dont lock up your brakes which can make your car skid out of control and crash.
Instead of locking up they gradually grab and release the disc brakes.
i said motorkhana not drift.... it can involve lots of hard breaking depending on course layout, not just to get the car sideways
i'm still yet to see how ABS would be a disavantage in a motorkhana. outright braking power will still be the same, and you get the advantage of still being able to steer while braking hard without the fear of locking up. up until the point of having a wheel locking up ABS is the same as non-ABS (you can still modulate the braking to be on the point of locking up and not actually have the ABS engage), but once you do lock up then the ABS is better.
good driver will outbrake ABS.
Of course a good driver will out brake ABS, I've seen it many times myself - but can you say that in every situation?
Unless you are epically well trained, you will jump on the anchors if say, a roo, jumped out in front of ya :)
And even with ABS on, if yuo out-brake it, then sweet. If not, then it's there to lend a hand
If all the conditions are perfect, you're prepared for it and you hit the brakes just strong enough not to lock up then yeah you can beat ABS easy. But as soon as you "slam" on the brakes in a moment of adrenaline, you're f**ked. ABS wins every time in that 'panic' situation because it gives you the option of steering.
I've never seen how ABS can be bad given it waits until a wheel breaks traction before it engages...ABS either kicks in or you're in a slide...
No flatspots on my tyres after DECA...!!!
i have raced both my R31 (no ABS) and my girlfriends R34 (ABS) on the same same and both had the exact same brakes r32 GTR drilled/slotted and R33 4 piston calipers.
there was a noticable difference between the two. The 31 felt like you could break harder before it would lock up a wheel although when it locked up you couldnt turn. The 34 seemed to lockup a little more, but it wasnt as noticable as such because you could still continue 'driving' on turn in.
my experience is for drifting ABS is not going to make a difference at all.
ABS is generally not preferable in a racecar situation, because racecars get into situations not common to road cars, and any decent driver should not need ABS anyway. One easy example is a spin where you want to lock the wheels up, I've head of times when people with ABS equipped cars have lost all braking power because the ABS system was overwhelmed.
There's a reason why the Porsche GT3RS and Noble M600 don't come with ABS.
I cannot do J turns with ABS pluged in in my 33, I may just be crap but my old MR2 (AW11 non ABS) loved them.
And I like the felling of gassing it to the entry of a corner and then mashing the brakes without fear of my crapness flat spoting my $500 tyres which acording to my budget must last 1 year.
this
and are epically calm. i've done driver training courses, etc that teach you about brake modulation, etc, but i've had animals and people run out in front of me and i can tell you that all of that goes out the window. you instinctively stomp on the brake pedal as hard as you can, and the closer you get the harder you push the pedal, regardless of whether the wheels are locked up or not. the reasoning your brain isn't consulted in these circumstances. it's all well and good to say about braking distances of a good driver in a non ABS car to an average driver with ABS, but that is in a controlled environment when they know they are going to have to brake suddenly. in an emergency situation that comparison doesn't work.
porsche carrera cup cars use a version of ABS.
as for the ABS being overwhelmed, a lot of people do the wrong thing when braking with ABS once it has kicked in. you will get people who feel the feedback through the pedal so they start lifting off and reapplying the brakes or pumping the brakes. this is the totally wrong thing to do. you are actually better off just keeping your foot buried into the pedal and letting it sort itself out rather the confusing it by altering brake pressure. also i think you may find that some of the braking failures may have been caused by either boiled brake fluid or the brakes overheating and glazing up, and if you get warped rotors and add that to the mix with ABS then you are in for all sorts of dramas.
yeah but how often does a roo jump out in front of you when your 'drifting or having fun with the car' *thread title*
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
