First thing I learnt in intro to law... you enter into a sale contract and thats it. He would have been pissed if you backed out. If he accepted payment thats accepting the sale contract. He can't just back out like that, but you're hardly going to take him to court over $150 worth of calipers...
I didn't win those other calipers either, so I'm keen on your mates calipers Big Fella!
How much are the seal kits? I saw a set of all four on eBay for about $200, which seemed insane to me just for the seals.
Hoping I might be able to pick them up from Big Fella, or a skyline owner on here upgradng (and maybe even get some second hand discs).
Get your money back for the others?
yeh there about $100 for fronts
rear calipers dont fit on our car so try asking if you can split em up..
yeh got money back.. should be picking the other ones up tomorrow or monday..
craig will.
give craig anything unbreakable and guess what? he'll break it
lol...yup!!!
you guy's looked around for R33GTR stuff yet?...might find them cheaper than Z33/V35 stuff!....front's only!
Just quietly Cam....big f#$king difference between a 20year old cross drilled rotor and a late model Porshe rotors and ceramic Ferrari stuff mate! Every time I have had crossdrilled rotor's on a car(any car) they have eventually cracked!
Edited by Jetwreck
You talking calipers? I've found R32 GTR calipers are cheaper than R33 GTSt. I didn't know R33 GTR fit?
The cost of a rebuilt set of R32 GTR calipers, decent slotted discs and decent pads had me looking at v35/350z stuff, but thats just dearer again!
Yeh callipers and rotors from a R33GTR.......they are basically the same calliper as the Z33/V35 brembo just black.....rotor is 324mm instead of 284 like the r32......will bolt up the same way as the R32's as well.....I know this as I started with the R32gtr calliper and rotors and just recently went to the R33GTR stuff.
Well u coulda told me that before I picked up my gtr32 calipers today.
Meh I don't think it matters, the way scotts was stopping was f**kin insane! I don't think I'll need more than that.. I'm not looking at track work anyway..
The ones I picked up look good.. The seals look new still!
So I'll need a caliper adaptor then?
The washer? Yeah I read Craigs instructions in M35Stagea.info, but he said R33 rotors were 324mm, and R32 rotors were 284, so I'd need that caliper bracket I think? This is the first I'd heard of R33 GTR calipers fitting?
Do they fit over standard wheels? I've still got standard 17" RS wheels.
Oh screw that I'm not going through that much trouble for a couple of mm. If that much trouble is needed, but he said they are the same as 350z brembos so maybe no adaptors.. Just the sleeve washer thing
Craigs Brain and possiblily other parts of him are on holiday ATM.
R32 GTR dicss are 296mmx32mm with Sumitomo calipers (same diameter as stock, the difference is in the width) Not 284mm
The R33 GTR are 324mmx30mm- With the Brembo calipers.
What you need to make them fit- the difference is in the bolts - R32 /33 being 12mm, and R34/M35/Z33 being 14mm (I think :blush:)
A little Sleeve that goes on the bolt to fill that gap is whats needed.
Scott might just jump in here (he turned mine up):thumbsup:
Edited by PN-Mad
R32 GTR, non brembo is 296mm x 32mm. R32 GTSt is 280mm x 28mm. The reducing sleeve for the mounting bolts is all you'll need.
Edit; Alex beat me to it.
Edited by Daleo
Scott might just in here (he turned mine up):thumbsup:
But wouldn't I need an adaptor to move the caliper to accept the bigger R33 GTR disc?
Does that make R34s bolt on too?
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
