Whats wrong with your 3 dials? My boost gauge isn't working, but I found a thread on Scotty's soldering fix, so I'll do that, get it working, then think about changing it :D
Iain has an RX, so no dials from factory.
when I got my suction pipe made by scott it increases airflow dramatically.
I think Cam experienced it too.
as well as scott jethro craig etc.
our Air flow signal cuts the engine when it reaches 4.80volts through the air flow meter(correct if a different figure)
You'll need to get it tune, and have the airflow clamped to get it to stop doing it. with an emanage etc.
mine has a 3inch pipe custom made from the turbo outlet to the airbox. if your doing that, I guarantee you'll hit an airflow cut.. just be ready for it!
Edit: and yeh stock injectors will max out with the suction pipe mod, which isnt very safe!
Yep, still experience it when I put the foot down due to still running the stock ECU (nor for long though :))
yeh it does.
I think Cams is currently a stockish size. and when mine was a stock size it was doing it..
Cam was one of the first Hiflows, IIRC, it just a mystery bag spec wise; might not be maxed as easily by a stock turbo?
Yep, my turbo is very close to stock size it would seem.
Look forward to seeing how early it comes on with a tune :)
Suction pipe eliminates the air supply restriction caused by the stock intake piping to the turbo.
Unfortunately opening this out allows too much airflow under full throttle for the standard ECU fuel system.
It may not do it with an upgraded fuel system though.
as cam said stockish size..
im pretty sure his one cuts at something like 4,500 right cam?
its not hard at all to get to 4,500
So... the long term solution is obviously injectors, fuel pump and emanage.
What's the short term solution? Take it off (which I'm sure will be a pain in the arse!)?
well you can drive it around as normal. i think the airflow cut will be saving your engine from running TOO lean in the top end where the injectors are maxed.
but you will experience an air flow cut.
put it all back on when you go for a tune and emanage install! with injectors pump spacer(depending on brand of injectors you might need a plenum spacer) etc..
all my stuff was sitting in my room until i wanted to tune!
EDIT: this is what I mean about the Domino effect!
Edited by AaronNM35
You were going well for a little while there Aaron, but quite wrong here.
Mine doesn't run out of puff at all.
Prior to the suction pipe, I could boost right up to the limiter without running out of puff.
what? lol
no i meant your turbo is a stockish size, but it didnt mean that it wont cut with a larger suction pipe.
When you put the suction pipe on, didnt your start cutting in the 4k RPM range?
my first turbo rebuild was a stock size inducer, with a slightly larger exducer - but it would still cut.
Once you install the suction pipe you'll get airflow cut. This happened with me and that's with the stock turbo, at around 4k RPM
I timed it so that after I got the suction pipe, I had Scott's hi flow and injectors installed the next week, then off to tune on the Saturday.
You'd also have to baby the car till its tuned (this is if you upgrade the injectors and what not)...I got sick of staying off boost pretty quick!
Depending on the size of injector you're upgrading to, you won't be able to drive it unless you've got a basic map put in via a piggyback. My car was at Scotts for a few days getting all the mods put in and when it was ready to go Cihan came to install emanage and loaded a basic map into it so I can drive it...
Edited by ironpaw
I think Aaron is saying after you had the suction pipe fitted you had airflow cut @ 4.5k RPM too?
no. i called him and explained what I meant.
It doesnt happen at specific revs.
it was just around where it happened...
It happens once your AFM receives and sends 4.8v+ to the ecu, from the increased air flow.
So the suction pipe doesn't max the injectors just the AFM? If that's the case wouldn't a fuel cut defender fix that by clamping at say 4.6V? If the injectors are maxed then obviously needs bigger injectors.
Surely you'll start leaning out the fuel mix REAL fast if youre doing it that way?
mine were maxing before it cut.
so my informeter told me anyway.
so i was forced to baby the car around lol
emanage can clamp the aiflow at 4.6 as mine is.. anything after that is mapped by a boost sensor plugged into the emanage.
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
