Finally I got something worth posting in this section.Today I installed my cat-back, BOV and smoked fender indicators, sounds nice now! Tomorrow the center dash comes out and I'm gonna make up a single din plate to mount up the 52mm gauges i got and maybe a switch panel to go in the ashtray nice and stealth like. Lovin the satisfaction you get from DIY
Edited by SatchiThaStagea
Well not so much something I did, but some little punk ass vandal bitch threw a rock at my car last night and smashed the right fog light. NOT HAPPY!!! :domokun:
Too dark to catch him, and I didn't realise that it was actually smashed until I got to my gfs place. Bulb is intact, just need the glass. Betting replacing it will cost enough to give me the irrits, but not enough to put through insurance, unless the paint is marked in the light of day.
In happier news, going round to Brad's shortly to get my stereo stuff done. Should take my mind off the fog light...
Glenn, sounds like good stuff, did you get your Nistune sorted too?
You heading to Kadina next weekend Ruby?
Sure am! Most likely heading up Saturday evening (after a kids birthday party) for the sunday show. Stag is in it. :thumbsup: Its Ford country up there, so I'm thinking of sticking some Ford badges on it :laugh:
The one I was looking at ended up not being compatable on account mine isn't a rs4, so the nistune will have to wait till I got the coin for the chip + tune.
Luckily I got plenty of other bits and pieces I can mess around with in the meantime. Didnt get anything done today, we'll see if I get round to it tomorrow
FINALLY installed the new head unit. has an extra feature i didnt realise. the music kept playing when i unplugged the ipod cable. yes, music over BlueTooth!
just gotta put the AUX cable in and run all the crap to the rear tv tuner, and finally mount that properly. maybe i wont show up to work tomorrow..........
Brad and I (well, mostly Brad :whistling: ) got the new head unit, HDTV tuner and English conversion installed.
Immaculate job, comes up looking almost factory with the head unit screen folded in. English translation unleashes some extra goodies too.
Couple of annoying quirks with the Clarion head unit, it doesn't allow AV IN while connected to the iPod (needs the USB cord disconnected) and we couldn't get around the video block. Should be able to sort the second one out in time.
Huge job, but everything went back perfectly and I'm very happy with the result. Thanks Brad!
nice work but does the blue tooth connection quality drop from cable??
always wondered!
ohh damn, i bet mine will do that too! might mean BT streaming for me........... i dont like the idea of unplugging the USB cable all the time as i want it plugged in permanantly and the video lead to the TV tuner AV input.
Aaron, quality didnt appear to change. but i couldnt get it up very lound due to neighbours. BT has enough bandwidth for a 128k/sec music stream AFAIK.
ouch thats a lot of coin. could put a car PC in for that price and do even more
Yeah I know...but I don't wanna deal with the windoze crashing or BSODing or some other shit that comes along with PC's...
Plus I get mates rate for this stuff anyway...
LOL...lucky you.
I'm sure BSOD's are always a layer 8 issue..never Redmond's fault right? :whistling:
Mostly, yes :P
Its like if you put Mazda 121 brakes on your Stagea, is it Nissans fault if you cant stop?
Mostly, yes :P
LOL...
Don't get me wrong, I love Win7, I run it on my HTPC and users have nothing but good thing to say after we've rolled out 500 new Dell's with Win7 on them.
I just can't be stuffed having to deal with a BSOD if, say, I developed a bad sector on the HDD where the MBR sits. Yes, running a SSD will minimise shit like that from happening...but I deal with enough of that crap daily. The Stag's my place of "zen"!!
I know a carputer is more flexible and whatnot but by the time I get all the parts the price is pretty close to what I can get one of these Alpine HU's anyway...
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
