i was going to buy a new gt2831 or something but garrett gave me this turbo for free and i cost me 200 in gaskets and clamps and i am happy. i was doing 14.00sec quatermile before i did half the mods so now i am hoping for at least mid 13s in the end i want 12s then i will take it to a race track and see how it handles. but we dont get paid to work on our cars so the work gets done afterhours.
They were 300 cheaper then the br's though.
I found a guy on here that sells the BC racing BR's for $1165 delivered (http://www.streettotrack.com/). So your Silk Roads are still cheaper (but only by ~$165) and I'm not overly concerned about it being harder to adjust damping.
Can you tell me if they can be set up soft or do they start at "firm" & go harder from there, as per most Japanese coilovers? But with a name like "Silk Roads" they sound so soft & comfortable LOL.
The aftermarket ECU and tuning will be the biggest difference. If you search forced induction you will find a thread by rev210 on how to get 12's on a 33 with as much stock gear as possible. The stagea is a lot heavier.
Nice find Leon, good prices there. Just curious how you'd go with warranty though, could be a sticking point?
I believe he is an official reseller and has such handles warranty the same as the others. He is just keener for the business so does some forum marketing in his spare time. He is quick to respond to email questions, which is great, so maybe confirm with him. The only downside is the delivery time for our cars is about 15 days. From that I'd guess he doesn't keep ours in stock LOL. But I am a patient man so that doesn't bother me. I've been waiting on some spare parts since Christmas......
got suck down the coast at albian park rail with a dead battery on saturday. NRMA only had a smallish battery with the small terminals. hope it lasts!!
I think I have the small battery.... :(
that sucks. i might change mine to the spare if its still around
i had a pitworks battery in there, has been in there since japan! not bad, lasted over 2.5 years.
3.5 for mine so could not complain.... Only paid $80 for the new battery delivered to my car.
last time i went to the drags i had 6 runs of times between 14.00 and 14.10 it was pissing me off i just wanted to crack into the 13s i had shit tyres so i was changing tyre pressure to get grip off the line and i only had done intercooler, boost controller and pod filter and was getting 1.9sec 60ft so low 13s is no problems.
this is only the 2nd car ive ever repaced a battery in
Lucky bastard. I think I've replaced the battery in every car I've had *touch wood*
Mine is a Pitwork too, hoping it lives a long, happy, healthy life :cheers:
I was going to ask if your alarm issues could be related to battery issues :P
I was going to ask you if your handling issues could be related to stilts issues :P
Haven't checked actually, didn't even occur to me. Will look into it. Thanks :thumbsup:
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
