Haven't checked (battery) actually, didn't even occur to me. Will look into it. Thanks :thumbsup:
Didn't you read my first reply to your alarm prob thread?
I had to replace the battery in my M35 a couple of weeks ago ($130 I think). The one that came out of it wasn't the original one from manufacture, but probably the 2nd according to the date. So a new battery every 4-5 years isn't too bad considering all the electronics on board.
Yeah you mentioned it, but I'd had no other reason to suspect battery. No obvious battery problems.
I'll grab the battery tester and check it, but I can't see it being the cause.
It's just gone off AGAIN so I've locked it and disconnected the battery.
Do these things have a backup battery? Is it possible that could be the problem?
Most factory alarms don't have back up batteries check the bonnett switich very common unplug the switich and test it over a few days if thet does not fix it you said there was sensors on the dash unplug them and see how that goes for a few days
Fitted my new steering wheel this arvo. Looks nice!
Not as hard as I expected; was stressing about the Airbag a little.
Same factory wheel as came out (just better condition), right? How long did it take you & did you need special tools - like those star head security doo dads?
Yeah, mine had fairly bad wear on the RHS through the paint down to raw leather.
About 20 mins; Disconnect both battery terminals with interior light on to discharge electrical system.
Pop the two small covers off the lower quadrants between steering spokes.
Undo the 2 T30 security screws and remove.
Gently pull airbag module free, and unhook cable from tab in centre of steering wheel boss.
On the back of the airbag, unclip the tabs on the side of the 90deg yellow plug. Pull tab away from plug slightly. This will allow the Airbag cable to come free.
Release plug/s for horn/wheel controls.
Put keys in ignition to release steering lock. This will stop you from damaging locking mechanism when you undo the mounting nut.
Ensure the steering wheel is correctly centred. THIS IS CRITICAL!
Use a 19mm socket and a breaker bar to undo steering wheel nut. It is tight; so brace the wheel with one hand (or get a friend to assist if you're puny) and turn bar anti-clockwise.
Wind the nut up until it's level with the top of the thread on the steering column. Do not completely remove. (This stops you being hit in the face by a flying steering wheel)
Centre steering wheel again.
Brace knees under steering wheel, pushing up hard; as if you're going to pop it off the taper. (You won't; it's effin' tight)
Use a drift, or a 6" socket extension bar and a decent sized hammer, to hit the steering shaft. Don't club it to death; you'll collapse the column, just give it a decent hit.
Repeat and you'll feel the wheel release from the taper. Only took a couple of firm hits for mine.
Completely remove 19mm nut.
Slide wheel off gently, and it's just the reverse to refit. Don't disturb the clock spring assy behind the wheel if you can avoid it.
If you're not confident with any of the above DO NOT EVEN ATTEMPT THIS JOB!!!!
Edited by Daleo
About 20 mins
You've done well to get all that done in 20 mins. LOL at leaving the nut patially on. I remember having to take the steering wheel of our ride-on as a kid. Took the nut all the way off, gave the wheel a big heave & it came off & smacked me in the head soooo hard, doh :wacko:.
20 mins is about right if you havent done it before.
i did mine in under 5. but it was the 3rd time in a row that i did it.
dont rush it, make sure you plug the airbag in properly!!
AFM died tonight on windsor road in the rain. lucky i had a friend to help me push it off the road.
didnt know it was the AFM. it just died and wouldnt start again. it would turn over fine (i did it a lot probably killing my brand new battery), stutter, then die.
big thanks to craig for phone diagnosis!
These things seem like consumable parts! It almost feels like if your M35 dies, its your AFM. I dont think I see anything crop up even CLOSE to as frequently. Almost feel like buying a cheapie and throwing it in the cubby hole
I'm know it's been up before, but what's the P/N, what else is it compatible with, (if anything) and is there a low cost source? As I'm sure Nissan Aust want a bit for one...
Edited by Daleo
AFM Nissan part number is 22680-6N211
It should be the same as used in the 2001-2007 X-trail and the 2000-2005 Pulsar
From memory, I got one @ trade prices for sub $200 ex-melbourne. Best bet for a 'cheap' one would be YAJ but you'll never know the story behind one of those. Could last a week or a life time.
I bought a new one from Nissan....FYI there was an updated part number from the original! So if you buy a new one it should last longer!
Just spotted this; I reckon it took me longer to write down how I did it, and reset all my settings on the bloody stereo afterwards...
Lol @ steering wheel accident! I know of so many people who've done it, probably seems very obvious; post head injury...
Edited by Daleo
Was the updated part number the one Dunc quoted? 22680-6N211?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
