Yes that's right . Gonna post some photo's online to show the workmanship.
Once again thanks to Craig and Andy for the setup. Nice work
finally ordered a 3" hi flow metal cat for the stagea, decided to go with the 100cpsi, that way the SA boys won't miss out on the campfire action on gear changeswhistling.gif
Got my car back with new clutch and re-dynoed
Looks like my GT3076R has shit itself at 18,000km old
Fun job of removing it tomorrow to inspect.
Man that sucks. Did it let go on the dyno?
Edit: never mind, just got your pm...
Edited by QWK32
No ALL good
The turbo was loose on the manifold. I went to start removing it and all 4 bolts where finger tight :blink:
Just put it back togather and took for a drive. A little greasy on road = a bit sideways in 2nd (AWD)
Love the new tune, only 20 more hp peak but and extra 45hp thru the midrange. What a difference
Drag day next Saturday.
Nice video craig where you testing the drive in motion for the Xanavi at that speed. What did the leaf look like. Pity the 34 wasnt in front would of been nice to hear your car a bit more at the end.
Sold my beauty yesterday. Didn't take long once the new pics went up. Car sold itself in person. Car is going to Adelaide. New owner is a genuine bloke and will look after it I'm sure which is the most important thing! The only question now is - what next!?
happy!!!
Well down pulling her up into the final corner... its always a tough one to judge how fast to go in.... I always want to keep pushing along that back straight and then i have to deal with the wall on the exit!!!
what top speed did you get down main straight how did she handle the kink before turn 1???
My old 4AGTE AE92 corolla used to get 180 down the straight farrkkk it was brutal through the kink but.... praying i could keep her straight to so i could drop anchor for turn 1 made me think some cars are just not designed for the track...
did you get a time recorded at all?? would like to know how it compares to other cars..
congrats!! or should i say sorry to hear??
you should turn a M35 into a masterpiece aswell.... since you did such a good job with yours..thumbsup.gifthumbsup.gif
got off the clock going down the straight....which was enough to pickup and go around some cars.....wasn't really looking at lap times as would not have wanted to depress myself with the Nankang(hangkang!!) goodness.
But I was doing 1:05's in the R32 with old tyres and no boost on it's first shakedown since the rebuild.
    • Intake manifold is not a part of the issue. The turbo bolts to the exhaust manifold. That is easy. But close your eyes and picture the physical situation. That is a T3 flange on the manifold and a T3 flange on the turbo. As long as any new turbo has a T3 flange on the exhaust housing, that exhaust housing will bolt to the exhaust manifold. This places the exhaust housing in the same place as the stock one. But now move your mental attention a little further forward. The location of the compressor housing is set by the length of the turbo's core. The stock turbo had a long core. Let's say that it is..... 100mm long. So that would place the compressor housing 100mm forward of the exhaust housing. But a highflow, might well have a centre core that is shorter. Let's say that it is only 70mm long. Now the compressor housing will be 30mm further back in the engine bay than the stock one. This DOES move the turbo's compressor outlet backwards. It also moves the compressor's inlet backwards. You will very likely have to do some work to both the inlet and outlet piping to make everything connect again. I am not say this to make it out to be a bigger deal than it is. I am just pointing out that "bolt on" is sometimes not quite bolt on. The highflow from GCG that Murray linked above (https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html ) uses a core that is the same length as the stock core, and so does not require this extra work. It will look very much like the stock turbo. No-one uses GTR turbos of any flavour (stock, or aftermarket) in a single turbo application on RB20/25. It's not a thing. Yes, people have been putting on GT3076, GTX3076 (and bigger and smaller versions of those) and G30s (of various sizes) onto RB20/25 since forever. But these are not "bolt on". Everything except the 4 bolts to the exhaust manifold change with these. And genuine Garretts are expensive. Non-gen, like Pulsar, etc, are cheaper, variously as good or nearly as good. But still not bolt on. No-one in the right mind would pay for an HKS turbo. Not in this modern day and age. Well, yes, the GCG highflow. You could ask HG what he can do to make the compressor housing sit in the original location. There are surely others doing highflows around the world. And some of the eBay/Temu ones (as reported by Dose) work and don't die. Bit of a lottery though. I would send your turbo to GCG (here in Oz) to be highflowed if you want a trivial no-extra-work option. But seriously, the work required to change inlet and outlet piping is not that hard. That's a boost control problem, not a turbo problem.
    • Thank you all for the replys 🙂 I know that intake would be different but that is one pipe at it is not that hard to get(custom one). I meant mainly bolt to the stock manifold and the turbo elbow. I looked and many sites/forums but they are just "old" with some old HKS turbos from GT-R i guess? What about some Garrets?  Or any other turbo? Is there even a turbo which i can just bolt on? 😄 And yeah i know about that new HKS but that is like 2000k USD without taxes/shipping in here   Iam getting a touch up tune but my "problem" is that on the "not" hot day iam getting peaks around 0,9 bar...and when it was around 15 Celsious i saw peak around 1 bar which is just too much for stock turbo. And of course turbo is old and i like to get some new one for a piece of mind 🙂
    • I'm working on the assumption that our friend Jasmine here is a Russian (or, possibly Ukrainian) spammer/spambot, based purely on the number of such that I have been having to neuter in the last few weeks. IP address for the OP above was in WA. But that could have been via VPN. Posting at quarter to 4 in the morning is a good sign of being from somewhere in Europe. The last Jasmine that I kicked in the cooch was IP addressed in Ukraine. Even that could have been via VPN, and the bitchbot could have been from Russia, Serbia, China or anywhere. Regardless, was a spambot, so I killed it with fire. The fact that our new friend Jasmine here did not respond in any way to my tart query strongly suggests to me that this OP was just the establishment phase of a user able to be activated for spamming in a week, or 3 or 10.
    • The stock manifold is "mostly" divided. The divider actually has a notch cut out of it where it would meet the divider on a twin scroll housing. I have no idea why. But whatever the reason, it would cause some cross talk when used with a twin scroll housing. People do put twin scroll housings onto that manifold. But I'm of the opinion that proper twin scroll internal gating is...not really possible at this scale. You'd be throwing good effort (ie $$) after bad, when you really should be doing something else. Notwithstanding that.... I am not sure what the idea that you are floating has to do with the difference in comp cover position caused by the highflow using a shorter length core than the stock Hitachi one. Can you clarify what you meant?
    • Majority of regulars are > 30. We all act at least 50. Definitely not friendly as we're all grumpy. 😛
