They poke out a bit, but nothing too crazy, just gotta roll the lips on the rear and you are sweet. just stretch some 245 tyres
225/40/19 :)
Stretchy stretch.
Might look at the TE37 in black now... don't want to look like I'm copying :P
TBH I prefered the old AXIS!
What'd u do with them?
BTW what rear bumper is that?
Aaron had the same wheels... so I had to change :teehee:
I posted up my old wheels for sale HERE.
I'm not too sure who makes the rear bumper, but its a Masa rear wing.
So they would be about 20mm outside the front guards unless you have a lot of neg camber to tuck them under a bit. Tyre killer! Lol
Im not exactly sure how far they sit out, but when you stand in front of the car or behind, they look completely flush. I will get a photo later today. :thumbsup:
dont tell me you changed coz of me dude. i feel bad now
Whiteline Group Buy Sway Bars fitted today (finally!). Also gave it an oil change and new trans fluid.
Then to finish the day off - a spirited :devil: drive with the new sway bars.......Gotta love doing something new to your car!!!!
Fitted up a brake master cylinder stopper this morning before I left for work. Was just a cheapy off eBay for a 33 GTST, but fitted up with no modification and am suprised at the difference it's made to pedal feel.
Got a Nismo S-Tune rear wing, and fitted it up.
Looks tops! :thumbsup:
Now want to try and do cruise, suspension, disks and wheels/tyres over the next month or so. Could end up just machining the disks for now, but it'll be more convenient to be able to do it all on one day, instead of waiting for disks to be machined.
Have you decided on wheels yet? A mate has a set of Nismo lowered springs for an M35 if your interested, not sure how much he after for them at this stage.
No I haven't. Looking at Braid at the moment, something a bit different, but I do like some of the Work wheels and those CE37s...
Not interested in those springs, thanks anyway. Shocks are shagged so I want to ditch the lot and go straight to coilovers. Seems the best solution. More interested in fixing it up than lowering it.
i did the same thing for the price and how it feels i love it
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
