Thats nice... Did you do that or Scotty?
What are you tuning on? I didnt think you had an emanage?
All mine I'm afraid. Scotty turned me up a beautiful "funnel on a flange" that was to go onto the turbo but I couldn't make it fit. I even cut his flange off and angled the funnel a little to see if I could clear everything but still no go. So I ended up making it, and all without a welder.
Oh, no E-manage, just voltage adjuster intercepting AFM signal. Have wideband meter so can DIY tune :rolleyes: .
3 inch dump 100 cpi racing cat , no resonator , varex 3 inch in 4.5 inch out cannon , sounds great . Had the wrong dump yet the guy at Bay Rd exhaust Cheltenham Melbourne 9585 4833 redesigned it , then he welded flanges on the cat and installed the varex for only $250 .So cheap.I would go to him if your in the area .
Couldn't make it work? Shame, it took me hours to make. :rolleyes:
The first intake I designed failed because the airflow sensor was mounted on a similar bend, I hope you don't have the same issue mate. How does it drive?
Yeah, it was a shame as it would have been excellent - soooo smooth. Thanks again for doing that for me.
Mine drives nice. It does need some fine tuning to get the mixtures right, but in my short 15 -20km test last night I couldn't see any issues that can't be ironed out. Maybe it's because of the smaller bypass tube below the main one?
i thought the bypass tube was cause it to go in limp, as its getting un metered air? or is that being fixed with the resistor
Leon, that IS awesome.
Nice work :)
I'd think it would just run leaner wouldn't it?
I mean the AFM is metering x amount of air, thus would supply the "appropriate" amount of fuel for that air volume.
If the other 25% is not measured, just means that there would be more air for the fuel map quantity.
EGT would probably be higher so that might make the ECU have a hissy fit, but can't see an issue with bypassing the AFM.
Maybe I am missing something?
Nice work :)
oh fair enough, im just going into comparison to having a leak in the system. which caused mine to go into a limp but only up high in the revs
your probably right though.. u usually are lol
Id have thought that it might go into limp mode also actually, if the O2 readings werent in line with what the ECU was expecting for a given AFM voltage
well my case.
i dont have a o2. i think the o2 only leans out the cruise(correct me if wrong)
i had a leak in my suction pipe as it wasnt secured properly. so it would only leak at high boost.
as soon as it leaked it was like the car hit a brick wall
thats after the turbo, its air that has already been metered, so the ECU knows about it.
this is tricking the engine into not knowing about the air passing around the AFM. its like having a leak in the piping BEFORE the turbo but after the AFM. it never gets under pressure
where do you think a suction pipe is out of curiosity?
before the turbo, after the AFM.
did you read what i said? a pressure leak AFTER the turbo is completely differernt to one before the turbo.
a leak after it will cause the car to run rich as air is escaping; one before will cause it to run lean as there is more air in the system than it thinks is there.
I'm sorry I missed all this discussion - had to work away all day :down: .
Just to clarify, the bypass is so the AFM doesn't hit a voltage ceiling. I'm probably not telling you anything you don't know, but here is my take on it anyway, for those not sure what it's all about..
Background:
When you increase the size of the intake you get more air flow (obviously - that's what you did it for, right) & it is possible (likely) that the AFM will hit max voltage (~4.8V) before hitting full load - especially if you've done other mods. A few of you guys have experienced this already, hence the emanage. If you have a larger intake experiencing this, the ECU won't/can't increase injector pulse width (more fuel) if the AFM sits on max V.
Solution:
By sending some air around the AFM, the engine gets the extra air it needs but the AFM doesn't meter it, so the voltage is lower across the range (ie shouldn't hit voltage ceiling). The ECU reads this voltage as less load & will drive the injectors less ie run lean.
Now we use a voltage modifier (interceptor) to increase the voltage that the ECU sees from the AFM at a heap of (200+ in my case) load points by varying amounts depending on what your wideband meter is reading.
Progression:
This also allows someone to increase injector size & then recalibrate/retune. Now the good part. If you have a device that can send a "fake" EGO signal to the ECU for when in closed loop (cruise/light load), there's no reason why economy can't be retained (or bettered) even when increasing injector size with the factory ECU. My wideband meter does this!
There endeth the lesson.
Cheers, Leon.
ok so what mine was, a leak before the turbo, after the afm.
up high in the boost it would set itself into limp after air crept through the silicone joiners..
sorry if i didnt explain properly birthday boy
Cheers, Leon.
So what is your Wideband O2 sensor.
Cheers
Andy
Cheers
Andy
http://www.14point7.com/SLC-Pure-Plus-2.php
Key Features
  • 0.01[Lambda] accuracy
  • Range; 0.68[Lambda] to Free Air, equivalent to 10.26[AFR] to Free Air for gasoline
  • Free Air Calibration of Lambda sensor capable
  • Digital display
  • USB connectivity
  • Multiple parameter display
  • Built in RPM pickup
  • Real-Time datalogging of multiple sensors @ 25 samples per second
  • Internal Memory for 2.9 hours of datalog storage @ 25 samples per second
  • Programmable Linear Output
  • Programmable Narrowband Output
Mine is the DIY version (of course, lol) & it doesn't come with the internal memory but otherwise the same. I need to have my laptop running in the car to log, but no big deal.
I have the boost sensor as well so it can be shown on the display as well as logged along with AFR, throttle opening, AFM voltage (has 2 x 0 - 5V inputs or G sensors). Having trouble getting RPM to register but haven't played with it for a few months. Must take another look at where I'm getting the signal.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
