Thats nice... Did you do that or Scotty?
What are you tuning on? I didnt think you had an emanage?
All mine I'm afraid. Scotty turned me up a beautiful "funnel on a flange" that was to go onto the turbo but I couldn't make it fit. I even cut his flange off and angled the funnel a little to see if I could clear everything but still no go. So I ended up making it, and all without a welder.
Oh, no E-manage, just voltage adjuster intercepting AFM signal. Have wideband meter so can DIY tune :rolleyes: .
3 inch dump 100 cpi racing cat , no resonator , varex 3 inch in 4.5 inch out cannon , sounds great . Had the wrong dump yet the guy at Bay Rd exhaust Cheltenham Melbourne 9585 4833 redesigned it , then he welded flanges on the cat and installed the varex for only $250 .So cheap.I would go to him if your in the area .
Couldn't make it work? Shame, it took me hours to make. :rolleyes:
The first intake I designed failed because the airflow sensor was mounted on a similar bend, I hope you don't have the same issue mate. How does it drive?
Yeah, it was a shame as it would have been excellent - soooo smooth. Thanks again for doing that for me.
Mine drives nice. It does need some fine tuning to get the mixtures right, but in my short 15 -20km test last night I couldn't see any issues that can't be ironed out. Maybe it's because of the smaller bypass tube below the main one?
i thought the bypass tube was cause it to go in limp, as its getting un metered air? or is that being fixed with the resistor
Leon, that IS awesome.
Nice work :)
I'd think it would just run leaner wouldn't it?
I mean the AFM is metering x amount of air, thus would supply the "appropriate" amount of fuel for that air volume.
If the other 25% is not measured, just means that there would be more air for the fuel map quantity.
EGT would probably be higher so that might make the ECU have a hissy fit, but can't see an issue with bypassing the AFM.
Maybe I am missing something?
Nice work :)
oh fair enough, im just going into comparison to having a leak in the system. which caused mine to go into a limp but only up high in the revs
your probably right though.. u usually are lol
Id have thought that it might go into limp mode also actually, if the O2 readings werent in line with what the ECU was expecting for a given AFM voltage
well my case.
i dont have a o2. i think the o2 only leans out the cruise(correct me if wrong)
i had a leak in my suction pipe as it wasnt secured properly. so it would only leak at high boost.
as soon as it leaked it was like the car hit a brick wall
thats after the turbo, its air that has already been metered, so the ECU knows about it.
this is tricking the engine into not knowing about the air passing around the AFM. its like having a leak in the piping BEFORE the turbo but after the AFM. it never gets under pressure
where do you think a suction pipe is out of curiosity?
before the turbo, after the AFM.
did you read what i said? a pressure leak AFTER the turbo is completely differernt to one before the turbo.
a leak after it will cause the car to run rich as air is escaping; one before will cause it to run lean as there is more air in the system than it thinks is there.
I'm sorry I missed all this discussion - had to work away all day :down: .
Just to clarify, the bypass is so the AFM doesn't hit a voltage ceiling. I'm probably not telling you anything you don't know, but here is my take on it anyway, for those not sure what it's all about..
Background:
When you increase the size of the intake you get more air flow (obviously - that's what you did it for, right) & it is possible (likely) that the AFM will hit max voltage (~4.8V) before hitting full load - especially if you've done other mods. A few of you guys have experienced this already, hence the emanage. If you have a larger intake experiencing this, the ECU won't/can't increase injector pulse width (more fuel) if the AFM sits on max V.
Solution:
By sending some air around the AFM, the engine gets the extra air it needs but the AFM doesn't meter it, so the voltage is lower across the range (ie shouldn't hit voltage ceiling). The ECU reads this voltage as less load & will drive the injectors less ie run lean.
Now we use a voltage modifier (interceptor) to increase the voltage that the ECU sees from the AFM at a heap of (200+ in my case) load points by varying amounts depending on what your wideband meter is reading.
Progression:
This also allows someone to increase injector size & then recalibrate/retune. Now the good part. If you have a device that can send a "fake" EGO signal to the ECU for when in closed loop (cruise/light load), there's no reason why economy can't be retained (or bettered) even when increasing injector size with the factory ECU. My wideband meter does this!
There endeth the lesson.
Cheers, Leon.
ok so what mine was, a leak before the turbo, after the afm.
up high in the boost it would set itself into limp after air crept through the silicone joiners..
sorry if i didnt explain properly birthday boy
Cheers, Leon.
So what is your Wideband O2 sensor.
Cheers
Andy
Cheers
Andy
http://www.14point7.com/SLC-Pure-Plus-2.php
Key Features
  • 0.01[Lambda] accuracy
  • Range; 0.68[Lambda] to Free Air, equivalent to 10.26[AFR] to Free Air for gasoline
  • Free Air Calibration of Lambda sensor capable
  • Digital display
  • USB connectivity
  • Multiple parameter display
  • Built in RPM pickup
  • Real-Time datalogging of multiple sensors @ 25 samples per second
  • Internal Memory for 2.9 hours of datalog storage @ 25 samples per second
  • Programmable Linear Output
  • Programmable Narrowband Output
Mine is the DIY version (of course, lol) & it doesn't come with the internal memory but otherwise the same. I need to have my laptop running in the car to log, but no big deal.
I have the boost sensor as well so it can be shown on the display as well as logged along with AFR, throttle opening, AFM voltage (has 2 x 0 - 5V inputs or G sensors). Having trouble getting RPM to register but haven't played with it for a few months. Must take another look at where I'm getting the signal.
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
    • I was able to get some underside photos while the car was on the ramp The suspension is all Altezza/IS200/IS300 so getting part's will hopefully be less of a headache
    • Welcome to my 2004 Toyota Mark ii IR-V Fortuna (series 2) With a 1JZ-GTE powerplant under the bonnet (hood) it'll give me plenty of scope for power upgrades. For those who aren't familiar with imports, the 1JZ-GTE is a 2.5L 6 cylinder VVTi engine with a single turbocharger. This has the factory R154 5 speed gearbox, along with a aftermarket 2 way LSD differential (brand unknown). Under the arches are a set of CST Zero 1 alloys, 18x9 +30 225/40 up front and 18x9.5 +15 265/35 on the rear. The car was quite low in Japan and there's evidence of the wheels catching the rolled arches/fenders. The tyre's aren't great so I'm in two minds whether to replace both or just the tyres and put up with the wider wheels on the rear. The car still uses stock brakes with the addition of some braided hoses. The exterior is stock with the exception of a BN Sports front bumper and a replacement Fortuna grill  Moving to the interior, the steering wheel has been replaced with a dished MOMO steering wheel (which will get swapped for my Momo Tuner for the time being) Defi Link Gauges are mounted above the climate controls and on the A pillar, the Oil Temp,Oil Pressure,Water Temp and Boost gauges should help with spirited and track driving  The stock seats have been replaced with some retrimmed Recaro bucket seats. Being a larger build these are a little snug, unfortunately the orange isn't for me so I'll look into replacing these down the line. Other modifications include a twin plate clutch, Blitz intercooler, Evolve alloy radiator, a stainless exhaust with decat, HKS EVC-S boost controller and coil overs
    • Apologies for the long read My R34 GTT was up for sale at the beginning of spring due to a few repairs creeping up. The strut tops needed replacing, roof and bonnet (hood) painting (yay for 3 stage pearl) and the underside stripped and treated. I sold the car which allowed me to be in a much better place financially. Leading up to the sale I was already thinking about the replacement. In an ideal world it needed to be a good all-rounder. Something I can mess around with, modify, do track days, do the school run, go on long drives etc.  Options included but not limited to... Laurel C35, Evo 8/9, Civic FD2, Impreza Hawkeye, Aristo and even an Audi S4 Avant (I've already got the Mazda 6 wagon). But there was always one car at the top of the list The Toyota Mark ii JZX110 I found an advert on a Facebook group for an example in Japan, from a seller called Jon at Rising Sun Exports. A few messages back and forth and Jon calls me from Yokohama one morning (or afternoon in his case). He briefly explained the import process, the costs involved and a repeat of the advert. After much deliberation, the price was agreed and the sale was locked in. I've never imported a vehicle so I jumped into the unknown head first. The money transfer was completed through wise.com (fees apply), very easy to use and the money was with him within a day or two.  The car suspension was raised for the vessel and the car dropped off at the port. It was 7 weeks later when the bill of lading was received and the freight invoice sent to me, followed by the export certificate a couple of days after (both digital copies) In the mean time the port had been in contact. I needed an agent to deal with the NOVA (notification of vehicle arrival) along with the tax/duty invoice, this was £75.00. The port also had a fee of £100, I'm guessing to cover the cost of the 10 day 'free storage' and for moving the car off the boat etc. They need a copy of the vehicle invoice, freight invoice and export certificate to allow the vehicle to pass through customs. The vessel arrived on Tuesday 5th August, the tax/duty invoice was generated and sent over. This is generally tax 20% and duty 10% of the vehicle value. Although the invoice came in at a higher amount than I had calculated. Once HMRC had received the payment the vehicle could be released from customs. I thought once the tax/duty was paid you could collect at any point, that's not the case. Your agent will need to book a collection slot, I requested Thursday 7th which was accepted, with a 9:00am slot allocated. It was a 5:00am start from Norfolk heading to Southampton. We eventually found the compound, upon presenting the bill of lading and some ID they released the car (they drove it out of the compound to the front ready for us to load up). The email from the port stated each slot had a 10 minute window, which seemed abit farfetched but the staff said it's not a strict rule. We were there for approx. 30-40 mins in total. A week prior to collecting I contacted my garage and explained the situation, I was able to get an inspection slot that afternoon. For the registration, DVLA require the car to be insured, for this I used a company called Adrian Flux who can insure the vehicle using the VIN number.
    • Hey guys, looking for these side skirts if anyone can help me out.
