Thanks to my new best friends at DBA, I have a new set of DBA 4000 Clubspec T3 brake rotors on their way, and thanks to Jethro I've got an idea of where to get some decent braided lines from. Combine all that with some HPX pads and some decent brake fluid, and it should be a pretty decent braking package without having to worry about getting calipers engineered.
Haven't ordered anything yet, but it's good to know that there are options..
http://fenixautopart.com/products_info.asp?selectclassid=002001028&id=242
Anyone put an alloy radiator in an m35 yet?
Edited by jasevr4
If the top tank is cracked you will definitely know about it. The Oring seals the whole underside of the top tank and usually only weeps when warm, sometimes it sprays out from one side.
yeah I looked at the one they had taken out, about a 4 inch split (hairline) just above where the tank mounts to the rest of it
Edited by MOUTH
As above, Iain and Craig have chinese radiators in.
I have a custom Race radiators item and Scott has a Mishimoto radiator.
If you are going an eBay special like Craig and Iain, make sure you get a G35/V35 radiator and not one for a Z33 (350z).
They are not the same.
yup the radiator cap is in the wrong spot for the intake vent that sits over the radiator.
if wherever you get it from specifies both Z33 and G35/V35 in the description, make sure its the right one.
craig had ours moved, and the mount points - the cheapo ones are good quality but the mount points may be off a little
So the Mishimoto radiators mount up quick and easy?
from what i have read and/or seen only the VQ25 radiators are the same, the VQ35 ones are wider, but putting them into a VQ25's spot is no biggie. trim away and it will be fine.
i used a hacksaw blade
Well, they do fit in place.... sorta
I brought it in initially, but could not get it to fit without cutting a ton of the support away.
I sold it and got my unit made up.
Still had to trim the radiator support to fit mine, but at least the fan shroud fits straight on and it is a very, very nice unit :)
Fan shroud does not fit back on the Mishi unit.
yes/no
scott had to shave abit of the fibreglass rad support.. IIRC
yes.... quite a bit
Yep I think Iain is right, not much is going to fit without a bit of trimming.
Might see if I can get a Koyo (http://www.frsport.com/Koyo-V2588-36MM-Aluminum-Racing-Radiator-Infiniti-G35-Coupe---Sedan_p_15744.html) for a reasonable price..
And of course a trans cooler as well, because plenty of them say "suit auto", but I'm guessing that just means they'll fit, because none of the photos show them with the trans cooler stuff on them.
Edited by jasevr4
350z radiators have the cap on the wrong side.
It will foul with your intake funnel into the airbox.
I am led to believe that the pins at the bottom of the tank that slip into the support holes are located a little too far forward or back (can't remember) on the 350z radiators.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
