Thanks to my new best friends at DBA, I have a new set of DBA 4000 Clubspec T3 brake rotors on their way, and thanks to Jethro I've got an idea of where to get some decent braided lines from. Combine all that with some HPX pads and some decent brake fluid, and it should be a pretty decent braking package without having to worry about getting calipers engineered.
Haven't ordered anything yet, but it's good to know that there are options..
http://fenixautopart.com/products_info.asp?selectclassid=002001028&id=242
Anyone put an alloy radiator in an m35 yet?
Edited by jasevr4
If the top tank is cracked you will definitely know about it. The Oring seals the whole underside of the top tank and usually only weeps when warm, sometimes it sprays out from one side.
yeah I looked at the one they had taken out, about a 4 inch split (hairline) just above where the tank mounts to the rest of it
Edited by MOUTH
As above, Iain and Craig have chinese radiators in.
I have a custom Race radiators item and Scott has a Mishimoto radiator.
If you are going an eBay special like Craig and Iain, make sure you get a G35/V35 radiator and not one for a Z33 (350z).
They are not the same.
yup the radiator cap is in the wrong spot for the intake vent that sits over the radiator.
if wherever you get it from specifies both Z33 and G35/V35 in the description, make sure its the right one.
craig had ours moved, and the mount points - the cheapo ones are good quality but the mount points may be off a little
So the Mishimoto radiators mount up quick and easy?
from what i have read and/or seen only the VQ25 radiators are the same, the VQ35 ones are wider, but putting them into a VQ25's spot is no biggie. trim away and it will be fine.
i used a hacksaw blade
Well, they do fit in place.... sorta
I brought it in initially, but could not get it to fit without cutting a ton of the support away.
I sold it and got my unit made up.
Still had to trim the radiator support to fit mine, but at least the fan shroud fits straight on and it is a very, very nice unit :)
Fan shroud does not fit back on the Mishi unit.
yes/no
scott had to shave abit of the fibreglass rad support.. IIRC
yes.... quite a bit
Yep I think Iain is right, not much is going to fit without a bit of trimming.
Might see if I can get a Koyo (http://www.frsport.com/Koyo-V2588-36MM-Aluminum-Racing-Radiator-Infiniti-G35-Coupe---Sedan_p_15744.html) for a reasonable price..
And of course a trans cooler as well, because plenty of them say "suit auto", but I'm guessing that just means they'll fit, because none of the photos show them with the trans cooler stuff on them.
Edited by jasevr4
350z radiators have the cap on the wrong side.
It will foul with your intake funnel into the airbox.
I am led to believe that the pins at the bottom of the tank that slip into the support holes are located a little too far forward or back (can't remember) on the 350z radiators.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
