So... Anyone got an xtrail or dualis?
Yeah, I've got an X-Trail, though it's a 2003 STR model if that makes a difference. What do you need?
I thought Bbenny had the best fitment, and spoolin. PN-mad looks like he has similar fitment now, so just go with that. :thumbsup:
Looks tough imho!
I believe Spoolin is 9.5 x 19" +22 offset now. Reckoned they needed a roll on the rears; nothing on the front.
Photos look EPIC!:worship:
Makes for one seriously angry Stag! :thumbsup:
Awesome! Are the rear license plate lights the same as the Stag? Or at least the same size?
The lights themselves, or the holders that the lights go in? The lights are just little spade LEDs, I replaced mine on sunday!
I think he was meaning the whole fitting. Possibly something to do with a reverse cam.
Sorry to say, in my case no. The Stag housing has 100mm screw spacing with a flat plastic cover. My X-Trail has screw spacings of 55mm with an old fashioned bulbous looking cover hidden under the tailgate handle.
Mine is an early model though. I think the more current ones could be the same. Can you drop by a Nissan place to have a look?
Spot on, looking at a wireless reverse cam that replaces one of the light holders: http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=130432830364&ssPageName=STRK:MEWAX:IT
You might be right. I'll drop past Main North Nissan and check the new ones. That would make sense if it was for X-Trail and Dualis, maybe that's the newer model X-Trail.
I'll check it out and let you know.
Spot on, looking at a wireless reverse cam that replaces one of the light holders: http://cgi.ebay.com....e=STRK:MEWAX:IT
Talk about going the extra mile, lol. I spotted a new X-Trail just now and measured the light surround. It is about 70mm long & about the same width as ours, maybe a little narrower. So although it isn't quite the same size, you may be able to make up something to hold it in there, since it is pretty well hidden on our cars anyway. I'm thinking thin aluminium sheet with cut out for new light/camera gizmo & holes to screw it into the Stag mount points for original light.
Cheers mate.:thumbsup:
Nah, not fussed TBH.:nyaanyaa: Maybe a set of PM skirts. Maybe.
One day...
also needs more low :P
lol nah kidding, looks good mate! im guessing with those wheels you CAN get big brakes under them?
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
