Jase, not that it helps now but to remove the double sided tape use a caramel wheel. My mate debaged mine and used this to easily remove the tape and gave the car a cut and polish. Can't tell there was ever a badge there.
Spent about 3 hours scrubbing away at the double sided tape/foam that the japs must have used for aerials. Unfortunately the previous owners never bothered to remove them so they were pretty much rock hard.
Also debadged the rear end.
Going to get some quotes on how much to spray my wing black/spray my new grille and fix a small dent in the passenger door and most likely respray the bonnet tomorrow. Previous owner did some "touch ups" that most people would refer to as graffiti. I'm hoping I can get away with all of that work for under a grand. No idea though..
How bad is it? I have a card somewhere for a mobile guy who does amazing work pretty cheap.
If you could trust him on my GTR can you pass on his number :thumbsup:
Yeah it really needs a cut and polish now. All of the tape has been removed but it just needs to be cut back to get the layer of crap off of it now.
They aren't that bad, just a hell of a lot of them. At least 10 chips on the bonnet that have been touched up.
I'll see if I can find his card and PM you guys. I want him to look at mine too.
He did some work on the front of my parent's old Audi Q7... couldn't even tell there'd been damage, and he did it all in their driveway for bugger all. From memory they found him on Solitare's recommendation.
Oh, and my BCs turned up yesterday! :banana:
None of my new stuff will be in before the cruise but I'm hoping everything will be done before the track day, except maybe the Emanage. Have to work a couple of things out first.
Yes very happy about the coilovers. It only took a bit over twice as long as I was quoted in the end :whistling:
You going to the cruise? Should try and make it, I want to check out this trans cooler and radiator!
Not sure yet. I have a birthday party and engagement party on that day. Of course I know none of the details. If you want to check it out sometime though just let me know. You're out north east, yeah?
I'm north, but yeah I'll be driving around the place on the weekend so if you can't make the cruise I can drop past some time.
If you haven't got the details for the cruise let me know, or PM Big Fella and one of us will send it to you.
Just got a quote from All Type to do my bonnet/wing/grille and a general tidy up around the place. Not half bad pricing, and from what I've heard - very good reputation. Just gotta wait until the wheels go on in case there's any.. accidents. :whistling:
Edited by jasevr4
+1 for All Type Crash
Went there to get my flaky spoiler and some front end damage from some idiot in a shopping centre fixed.
They did a good job, in a short time at a good price. Ruby also got his respray there and while I was there saw 2 other stags getting fixed so they know how they go together/come appart (c34's atleast)
Having said that if you go to Willaston Paint and Panel and tell him (edit* Matt) that Glenn in the yellow stag sent you he'll sort you out
Edited by SatchiThaStagea
Hayden's a champ, and everything I've seen from All Type looks awesome.
Today I ordered my HDI intercooler. Just have to decide on a power steering cooler, then I can order the trans cooler too.
Anyone running an engine oil cooler?
I don't think it's required, even for track work, but I would be keeping an eye on the temps...
I think Jetwreck has popped a P/S pump due to trackwork. But tend to agree, cooling p/s fluid for non-racecars might be a bit over the top... (Because Racecar... you know)
Interestingly - my car has a small stock P/S fluid cooler - just a finned U bend, sits just behind the grill.
I spoke to Craig last week, he said he'd found a power steering cooler was essential, and a trans cooler was recommended.
Looking into it, g35s and z33s seem to all have had stock power steering coolers, with Nismo and Stillen making enlarged aftermarket units.
So Im confused why we dont have one, but I will get one soon, just have to finish my research. :cheers:
Because our car was not really designed as a ..... Track bitch......more of a family cruiser.....had they done a sports version of the m35 like the 260rs.......well we have all seen the 380rs haven't we!!!
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
