The thread I was looking at yesterday said there was a cross brace in the way, but it could be possible?
Apparently the Bose amps fit under the toolkit, so I'm hoping normal aftermarket ones do too.
The only thing i would be worried about there is sufficient ventilation.
Oh so the standard Bose unit isn't powered? Has external amps?
That's what I read yesterday, Iain would be able to tell you for sure since I'm pretty sure he wrecked one.
Did you check out this thread? http://www.skylinesaustralia.com/forums/topic/255109-m35-stereo-lots-of-piccies/page__hl__speaker
Great thread! I have a fold out single DIN TV/DVD/GPS at the moment. I'm really keen to replace it with an OEM unit and a single DIN that will display through it.
I just checked out my car and nope, there's no way that one of those long powered subs could fit under the tool box. A small enough amp could definitely fit on the right hand side though.
Come check mine out then. I do want to see your radiator and trans cooler. Was going to look on sunday but you piked!
Piked makes it sound like I didn't do anything. I wish! :rolleyes: Haven't had a weekend off since being back in Australia..
my ariel leads came in the mail from the UK today. So installed them along with my FM Radio extender. Now i have FM radio.......... Oh the sweet sweet sound of no more AM radio stations. Next is a service. . I have a feeling that my turbo is leaking oil. Started smoking on that side of the engine after not starting engine for a week. I have suspected it as i have had blue smoke upon startup for a few months now. Might be time to check my turbo seal aswell.
that would be such a relief if its just a rocker gasket.. Do you have a part number? Prob get both sides done at same time
Take your VIN number to a Nissan dealer. They'll have to order the gasket regardless, nothing else is a match. Cost is around $29- $30.:thumbsup:
Finally got the dump pipe fitted up today after having Captain Thread fix 2 busted studs yesterday. Big difference in performance from the stock dump.
I also noticed an increase in boost, not sure how much as it now seems the factory boost gauge is maxing out. Does anyone know how much boost increase they got from the dump and if the stock turbo can handle running a couple extra psi without destroying itself? Im just a little worried that by fitting the dump to try and extend the life of the turbo, the extra boost with destroy it sooner than before.
Also anyone know where I can get a flange gasket to suit the stage flange? It appears to not be a 3" flange gasket.
Edited by slippylotion
3psi, thats more than I expected. Do you have an a/market gauge fitted?
The oil feed won't make a difference to the extra boost, its the extra shaft speed and heat that the ceramic turbine wheel will see that will cause it to go.
I know that the ceramic turbine wheel on the RB series don't like any more boost than 12-13psi, after this the shaft speed and heat cause the wheel to break or shatter.
No thats based on pressure measured on the dyno. Stock is 12 psi, on sausa dyno day was showing 15.
Scotty drilled his banjo out and i think he was running stupid amounts of boost without it going bang?
My banjo restrictor wasn't drilled but I cleaned it out, ran 19-20psi on the stocker for over 4 months with no issues.
Our stock 14psi boost would be too much for the older RB series ceramic turbos.
So you used a boost controller to up the boost more than what the exhaust/dump gave?
Are the turbo's that are dying from the exhaust wheel coming off or the core dying due to seals or bearing failure?
If the bearing assembly starts to fail; the exhaust turbine will be able to make contact with the housing; thus breaking the fragile ceramic blades.
I don't think any of the failed turbos have actually dropped the exhaust turbine; a-la RB turbo; only smashed the blades.
The reduction in heat buildup around the exhaust turbine by fitting the dump pipe, far outweighs any risk of failure due to excessive shaft speed IMO. I fitted the dump by itself on a factory exhaust and I'm convinced it makes the turbos life easier.
You are limited in a standard configuration to around 14/15psi anyway; due to the restrictor in the wastegate line. Even with a full 3" system and 100cspi cat mine won't go over 15psi.
With the 7psi actuator its hard to run any more than that, even with a controller. You may get 20psi midrange but it will always drop to around 15 by redline without increasing the spring tension on the wastegate.
The exhaust manifold pressure literally blows the wastegate puck open on boost bypassing the turbo hence welding a stiff spring to the actuator to hold it better.
All the stock turbo failures I have seen have been due to oil starvation/heat on the rear bearing as Dale mentioned.
    • To back this up, I'm always looking on the outside, seeing the level, and then opening it up anyway, as I'm worried the level I've looked at, is more so a scunge line. Then you end up dipping your damn finger in it too depending on the type of tank you're looking at just to make sure I'm not going insane.   PS, Mark, polish up the none moroso one a bit and then give it a clear coat. The Moroso one looks to be way shiner (not mirror polished, just shinier) and it'll still look weird with the two different alloys beside each other. Either that, or Id probably paint them a flat black...
    • Good old Orange Park hey... 😛   f**k I miss that race track
    • lo, it was a death trap. Good times. Got any Fatz Drift Day DVDs still available?
    • Yes, overthinking. Many PS reserviors are completely opaque. Our Skyline ones, for example. Have to remove lid, peak inside, swirl the dipstick, try to remember how to read it, etc etc. Normal. Radiator overflows are often sufficiently opaque and scunged up that you can't see the true level inside anyway, and have to open and have a peak. Besides which, I replaced the (massively expensive, even back then) plastic overflow in my Alfa GTV, back in the '90s with a stainless one that I had a good fabricator make up to be dimensionally same-same, that looks remarkably similar to the Bogan's Moroso one above, and I never suffered any particular paranoia that I didn't know how much coolant was in it.
    • Looks great, but I'm always concerned that it makes it difficult to see what level the fluids are at. Am I overthinking this?
