Nope, same as any other VQ. Not sure if anyone in Adelaide stocks them, I ordered mine online. Apparently Autobarn have the Blitz filters with the magnets though.
Craig, this is the tin?
$98 for 5L from GCCorp.com.au
So I finished fitting the intercooler today. Only thing is I've now got a bit of white smoke. Not sure if it's burning off the excess WD40 I used on the silicon joiners or what, but hopefully it goes away after a bit of a drive.
I had the same thing when I fitted my intake suction pipe (more than a bit of smoke too) which I was convinced was the oil blowing out of the standard intercooler. It only happened after a boost event & only after lifting off. I swapped the factory intake back & the smoke went away, thus proving my point.
Except....
When I put the HDI cooler in last week & reinstalled the suction pipe, there was the smoke again (Dale was still coughing some out of his lungs over lunch last Sunday) under the same conditions. It seems to be getting slightly less the more I drive, but I now think what I am seeing is more to do with oil getting sucked into the plenum from the PCV, not left over oil from the old 'cooler still being in the throttle body/plenum.
I'm getting a catch can for that hose & maybe replacing the PCV valve if excessive oil is captured.
Maybe you could look into the same solution?
Edited by Commsman
One step ahead of you Leon! :thumbsup:
Catch can is sitting in my boot ready to install, hopefully on the weekend. Just need to make up a bracket.
Couldn't believe the amount of blowback when we pulled it apart for a spark plug change.
Except....
Lol, I was sure I could hear you two shouting "Release cloaking device!" before disappearing into a cloud of smoke...
Our engines seem a bit sensitive to this for some reason. I'm wondering if our PCV valves are stuffed.
I have a catch can on the other (suction pipe) side & there's not a drop (or even a smear) in the clear plastic hose, let alone the can itself. If the amount of smoke I've been seeing when driven hard is an indication, I may need to empty the PCV one weekly, lol.
Haha. I was doing my Bond impression. In actual fact, I was trying sooo hard to keep off boost because I knew what would happen if I gave it a little bit.
On the way to/from Sydney I was imagining what people were saying when I passed them, just to cover them in a cloud of white smoke when I lifted off. "Look at the POS wagon...." So embarassing
Brief offtopic; you guys had a good run back to the F3 from Wisemans? Good to meet you and your young bloke too.
Interesting story. It took us 45 minutes from leaving the ferry till we got onto the freeway. Considering it was all 60, 70 & 80 zones (& double demerit weekend), wet & unknown roads (is that enough excuses?), I thought we made good time without taking too many risks. We overtook a Commonwhore who then proceeded to chase us down on the next 2 straights (cornering pace was pretty average) before giving up. However Craig reckons it was too slow but, as Tina says, we don't need another hero, lol.
And it was good to meet you too.
Edited by Commsman
Commonwhore knuckle draggrers hey, when will they learn?
Had exhaust fitted today. JJR front pipes, catco highflow cat, custom made mandrel bent 3" piping with 'hotdog' style resonator in there somewhere. Oval powerflow performance muffler and twin chrome twin tips to keep stock look. Xforce dump pipes, Denso 720cc injectors, nismo fuel pressure regulator, walbro 255l fuel pump, power fc, greddy profec b 2 boost controller waiting in the shed to be fitted when nismo gt le mans group a turbos get here and aluminium radiator and new silicon hoses on the way (found a crack in top radiator tank) :-(
That'll be the oil Craig is referring to.
Really good stuff :)
Have you used it yet?
It'd want to be really good stuff considering the buggering around to get some!
yes, the 10w40 I have used and preferred the feel of the car to when it had Redline in it if that reference means anything for you.
would you really keep it in your car for 40,000km though?
Bottom end is back together, everything should be bolted up by Monday and nesstled in the engine bay by mid-next week. End next week should have my C34 back!
YaY!
Only thing to be looked at in the future would be sorting out the mirror rust and tidying up some areas of the body, as not much else would be "stock". 6yrs in the making.
However, over the next 4-5yrs, I'll be using the car minimally as I plan to get the train into the city for my up'n'coming Uni studies. I cant forsee myself spending anymore on this stagea. Perhaps the rust/re-paint and perhaps a Z32 Nistune ecu setup, but thats it.
fixed a little gutter rash on one of my wheels, and realised that the outside of the tyre is wearing more than the inside spank.gif
good work on my alignment beaurepairs, guess i'll change the tie-rod ends sooner rather than later then
No, although I am sure it could stand up to 20,000kms of daily highway travel... much like Sougi can/could :ph34r:
fair enough. still worth it at that price.
especially seing as sougi 6000 isnt readily available anymore, and comparing to the price of 300v.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
