Im putting adjustable rear toe arms on tomorrow if you want to check it out? No camber adjustment though.
from what i understand there is no reason to waste HUNDREDES of dollars on camber or toe arms etc as u can adjust the stock stuff 1degree and if u want more bushs can add another 1degree
just saying :ninja:
just saying :ninja:
Prob not... But then I didnt spend hundredes... Or hundreds... :ninja:
Got my BC BRs in and setup, but will have to play with it again to get it right. Hard to judge when your wheels are a metre inboard... NEED MOAR OFFSET!
Rear DBA Clubspec rotors went in, and QFM HPX pads.
Washed the dirty wench, gave the exhaust a polish. Found Wurth Intensive Rim Cleaner cleans up the titanium well!
Filled up with 100 octane e10 at United, bloke tells me I need to try e85 in my "sports car"...
Didnt put the toe arms in. Will get them fitted when I get it aligned. As soon as I work out where to take it.
Have you got a part listing for the bushes for camber? As yet I can't find them.
call Wholesale Suspention in Penrith im pretty sure they can get ahold of them or i think they said they are the same as a 350Z???
Its advertised here on SAU, only. Genuine reason for sale - House still hasnt sold yet after half a year under contract, I cant afford morgage repayments & am on the absolute bones of my arse. Pretty much hit rock bottom 2 months ago, which is a good thing in all honesty as I made myself get off the medication that sent me crazy.
Heart says Im silly to "give it away", head says to be smart about it. University is my #1 priority for the next 4 or 5 years.
I'll get stuff all back from the house sale, when it eventually sells (been screwed over by the agent),and will need it all to cover living costs.
Funds will be too scarce while at Uni to run the risk of anything going wrong, even general maintenance, on the Stagea.
I really dont want to see it gone, but all my time will be focused on succeeding with the Medical Radiation Science course. For the first time I just dont see my pride & joy being in my future - however I now see a future for myself. Just need a little run around car to run errands as I'll be using public transport during the weekdays to/from Uni in the city.
Considering Ive spent well over 50k all up, including car purchase, 15k is probably letting it go too easily, but perhaps its the right option in my current circumstances. Whom ever buys it, whenever that happens, will be getting something pretty special.
Sad about it, nonetheless.
REALLY??!!
What is it with everyone selling their stag's at the moment??
Ive had it for well over 6years, and am one of the only remaining "original" stagea sau:forum users still here.
Genuine reason for sale, not "just because".
Nnnnnoooooooooo...
:(:ban::rant::spank::down::domokun:
Feel absolute ratshit about my decision to advertise it here, but I cant see anyway around it.
+1, sounds like the 1 step backwards before taking 2 steps forward.
Good to hear you've conquered your painkiller demons; the start of the new beginning?
It was a long time ago, but when I was an apprentice earning peanuts, I watched all my mates seemingly spending money like it was water, and it did my head in, but things change trust me, and some of my best memories were of those years I struggled to get by.
The time will fly by and soon this'll be a distant memory; especially when your circulating at your favourite racetrack in an R35 GTR... (well maybe not; but you get the idea)
Best of luck with the sale & the new career too; sounds like it might be your turn now.
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
