I wish it was, but checked that previously. By following the trail it could only be dripping down from the valve gasket (preferred) or coming from on top of the turbo. Only seems to leak after "proper' drive, not idling in driveway, so oil under pressure by the looks of it.
The oil line to the turbo could be split but I think you are right, the washers for the banjo may need to be replaced. :(
I may be driving up to Sydney this week, want me to fix it for you? Swap you for a cruise install. lol.
Took her out for the first half decent drive with it, to get acquainted and such.
Very happy with it. I did find it a big laggy for an NA so Im thinking Im going to have to put a kit in the gearbox.
The guy I got it of said it was a Four wheel, turns out its rear wheel.
Haha, I would be tempted to drive the 8hrs to Sydney if you were serious. But I know you have that cruise mostly sorted now, so I have nothing to trade (except some folding plastic).
bought some new upgrades over the weekend, dual stage turbosmart boost controller, cooling pro FMIC kit, 550cc bosch injectors, walbro gss342 pump.hopefully my r33 will sell pretty quick so i can buy a hypergear tr43, lowmount manifold, and nistune to get it all sorted before sau nationals this year :D
Edited by OMY31T
dirty great box of Greddy goodness arrived today: that would be my suction kit... :)
waiting on Z32 afms which are on their way, and Nismo engine mounts: excitement!
Oh, and PWR ended up being a lousy bunch of not very nice people: The best they offered was a brand new radiator to my previous spec (inbuilt fluid coolers, triple cross-flow, etc) at a discounted rate.
Given that I would only expect it to last 18-24 months, pretty sure I'll pass, and buy a Jap name-brand unit (thinking Blitz), and run external oil and trans coolers... More than mildly disappointed at the outcome, but what can you do?
I will NEVER recommend their product to anyone!
bought some yellow jacket coil packs off ebay the other day fitted them had a missing issue then upgraded spark plugs (which I should have done in the first place) and now she runs a million bucks :)
Cruising on the highway and noticed the car was surging, gf pointed out that the torque split gauge was nearly on 10
Looks like I'm up for new rear tyres to match the new fronts :-(
Hi guys! I'm new to this site. I've got myself a nice 260RS in 2010. Since then I've had HKS hard piping put in, 3" turbo back exhaust, Nismo clutch, rebuilt gearbox, spitfire coils and a haltech ecu installed and tuned. It came with Tien coilovers. Now I'm looking to do a single turbo conversion in a few months just to bring spool up a lil.
What did you decide on in the end?
Still haven't decided; tossing up a 2860RS or 2871 core.
Exhaust side of both is identical, but the compressor exducer dimensions are 11mm different, so I'm not 100% sure.
Also the 2871 has thee trim options, 48, 52 and 56. On my SR I've had both the 48 and 56. I noticed no difference in boost response but did notice the 56 had more power up high.
On my SR it was making 18psi by 3800rpm with .64 exh so we could assume the vq25 would deliver 18psi around 3000-3200? Check with brad what his response is like as he uses a 2871 on his M35 but I don't know what trim version. I'd assume 52 trim as this is the most common version being a hks gtrs spec.
If your after closer to factory response I'd go the 2860 wheel, I will when mine fails but hopefully a while away still.
Edited by slippylotion
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
