I don't know if your mate is my mate (Chris from Craved Coatings), but he did the radiator, oil cooler and sump on my race car, it definately ran a degree or 2 cooler afterwards. When you are pushing everything super hard, every degree makes a difference.
Duncan, my mate is in Penrith also; but it's not Chris. I've seen the Powdercoating that Chris does & his work is amazing, my mate is only just getting in to the decorative coatings, and there's a few ceramics (the polished finish ones) he does that Chris can't do.
You're dead right though; at the limit, every little bit makes a difference, and there al all kinds of coatings, heat shedding, heat retention, heat reflecting, anti scuff, lubricant holding, lubricant shedding; the list goes on and on.
I'm really going to have to investigate these coatings more because I drive my nimble beast at the limit every time I take it out.
LOL.
The creaking and clunking tune it makes now is horrible. Seems everything is coming at once ATM. Attesa pump, cam cover seal and piano bushes. That's three so hopefully good for a bit now ?
Edited by slippylotion
Update; Turbo is out now. :banana:
post-61153-0-47778500-1343300106_thumb.jpg post-61153-0-45897300-1343300163_thumb.jpg
Truly there has never been a better example of the right tools for the job than this job.
After wasting hours yesterday with the heatshield bolts; we bought two Snap On spanners and a 3/8 drive 10mm single hex socket. What couldn't be achieved in several hours; removing the heatshield was completed in around 20 minutes. This cleared the way to finally free the turbo from its home.
I've also modified the offending heatshield so that the remaining section can be refitted; all the bolts can now be accessed, and it can be completely removed in about 2 mins.
In other news, the exhaust housing, dump and mid pipe have now been blasted, baked, blasted again, and coated in the thermal basecoat.
It has now been baked out and is cooling. The external thermal coating will be going on tomorrow, with the internal coating for the exhaust housing and dump to follow.
post-61153-0-82551900-1343300963_thumb.jpgpost-61153-0-60004400-1343300888_thumb.jpgpost-61153-0-53352900-1343300874_thumb.jpg
The coating goes on a greeny colour as seen on the Dump & Mid pipe; then dries almost white, as seen on the exhaust housing.
Once baked; they are almost completely white.
Edited by Daleo
I can get some numbers for you tomorrow; they're about $55 each though. I'm planning to marry mine.
I didn't take a pic of the heatshield, but I'll get one tomorrow.
Sweet, thanks. Should start getting the tool kit in order for when the inevitable happens.
What is the gap like on the rear wheel from the housing? It looks to have huge clearance, is it just the photo?
That's only a baby turbine, should be responsive. Good choice buddy. :)
My special tools... Cost : $0 ;)
The clearance is reasonably tight; I think it's just the pic, there's a couple of funny reflections & shadows. The coating will close the clearance down slightly too.
I'm hoping so; we'll see in a few days.
Trust me; if the Snap On truck hadn't been in the corner, we'd have been doing the same. I already had one long spanner made up.
Paul, I took some measurements today, but I left everything at the workshop.
I forgot to mention, I received these springs in the mail today, should hold the gate shut till around 26 - 30 psi. :)
Install tomorrow along with the thermo fan controller.
Anyone for a 3.5 inch dump?
And the new torque converter, packing triple Pathfinder lockup clutches. Not sure when I will get time to drop the gearbox again...
    • Mine is all -12, I’m running a dry sump in a billet block though
    • HG's high flow is not "bolt on". The core is shorter, moves the comp cover rearwards in the engine bay. means you have to deal with the inlet plumbing a little bit. This is probably something to consider with every "bolt on" turbo anyway.
    • HyperGear. Just get a high flow of the stocker. Good, reliable, and should bolt on. Yes it will want things like a retune once done, so you need to factor this in to your spend too.
    • Hi. Iam looking for some "cheaper" bolt on turbo on RB25DET NEO. I do not want "big" power just better reliability than the stock turbo which is "fot now" good but is old and i do not think it has "easy" life. One the Skyline here running some "temu" china Turbo but i dont trust those... Thanks!
    • Hi guys, Making some space/cleaning up. A whole heap of random OEM R33 GTR parts and other random bits and bobs. I will update this thread as I go. Parts are located in Moorebank NSW 2170. Pickup preferred but will post at buyers expense. Prices are negotiable. If they don’t sell it will go in the bin. Item 1: BOV return pipe. $40 Item 2: RB26 cam gears. $20 Item 3: R33 GTR torque split, oil temp, boost centre gauge. $100 Item 4: RB26 fuel rail x 2. $20 each Item 5: RB26 Recirc valves. $50 Item 6: OEM upper front arms. $20 Item 7: Royal Purple Max Gear 75w-140 1 quart/946 ml x 5. $50 each or 5 for $200. Item 8: OS Giken 80w-250 diff oil 1 litre. $25 Item 9 Eibach springs. ers-11-140-60-0140. $100 https://www.streetfx.com.au/eib140-60-0060-eibach-ers-140mm-length-x-60mm-id-coil-over-spring?_ga_campaignid=22235933977&_ga_adgroupid=180146800292&_ga_keyword=&_ga_device=m&_ga_target=pla-295238231169&_ga_locint=&_ga_locphy=9071723&_ga_matchtype=&_ga_network=g&_ga_device=m&_ga_placement=&_gcl_id=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE&gad_source=1&gad_campaignid=22235933977&gbraid=0AAAAADPiTbo1xAuvnjIWWYnezivf-BUSY&gclid=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE
