I don't know if your mate is my mate (Chris from Craved Coatings), but he did the radiator, oil cooler and sump on my race car, it definately ran a degree or 2 cooler afterwards. When you are pushing everything super hard, every degree makes a difference.
Duncan, my mate is in Penrith also; but it's not Chris. I've seen the Powdercoating that Chris does & his work is amazing, my mate is only just getting in to the decorative coatings, and there's a few ceramics (the polished finish ones) he does that Chris can't do.
You're dead right though; at the limit, every little bit makes a difference, and there al all kinds of coatings, heat shedding, heat retention, heat reflecting, anti scuff, lubricant holding, lubricant shedding; the list goes on and on.
I'm really going to have to investigate these coatings more because I drive my nimble beast at the limit every time I take it out.
LOL.
The creaking and clunking tune it makes now is horrible. Seems everything is coming at once ATM. Attesa pump, cam cover seal and piano bushes. That's three so hopefully good for a bit now ?
Edited by slippylotion
Update; Turbo is out now. :banana:
post-61153-0-47778500-1343300106_thumb.jpg post-61153-0-45897300-1343300163_thumb.jpg
Truly there has never been a better example of the right tools for the job than this job.
After wasting hours yesterday with the heatshield bolts; we bought two Snap On spanners and a 3/8 drive 10mm single hex socket. What couldn't be achieved in several hours; removing the heatshield was completed in around 20 minutes. This cleared the way to finally free the turbo from its home.
I've also modified the offending heatshield so that the remaining section can be refitted; all the bolts can now be accessed, and it can be completely removed in about 2 mins.
In other news, the exhaust housing, dump and mid pipe have now been blasted, baked, blasted again, and coated in the thermal basecoat.
It has now been baked out and is cooling. The external thermal coating will be going on tomorrow, with the internal coating for the exhaust housing and dump to follow.
post-61153-0-82551900-1343300963_thumb.jpgpost-61153-0-60004400-1343300888_thumb.jpgpost-61153-0-53352900-1343300874_thumb.jpg
The coating goes on a greeny colour as seen on the Dump & Mid pipe; then dries almost white, as seen on the exhaust housing.
Once baked; they are almost completely white.
Edited by Daleo
I can get some numbers for you tomorrow; they're about $55 each though. I'm planning to marry mine.
I didn't take a pic of the heatshield, but I'll get one tomorrow.
Sweet, thanks. Should start getting the tool kit in order for when the inevitable happens.
What is the gap like on the rear wheel from the housing? It looks to have huge clearance, is it just the photo?
That's only a baby turbine, should be responsive. Good choice buddy. :)
My special tools... Cost : $0 ;)
The clearance is reasonably tight; I think it's just the pic, there's a couple of funny reflections & shadows. The coating will close the clearance down slightly too.
I'm hoping so; we'll see in a few days.
Trust me; if the Snap On truck hadn't been in the corner, we'd have been doing the same. I already had one long spanner made up.
Paul, I took some measurements today, but I left everything at the workshop.
I forgot to mention, I received these springs in the mail today, should hold the gate shut till around 26 - 30 psi. :)
Install tomorrow along with the thermo fan controller.
Anyone for a 3.5 inch dump?
And the new torque converter, packing triple Pathfinder lockup clutches. Not sure when I will get time to drop the gearbox again...
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
