I have read the tread a while back i just wondered what he ended up going with.
Cheers lads
Also, nothing that hasn't been talked about enough already, a mob in Adelaide I spoke with last week regarding tuning who have quite a bit of exp tuning M35's are of the opinion that these cars are popular enough to now support. I sent him an email regarding what i hope to achieve and they are gonna get back to me.
The are into keeping and tweaking stock ECU's (i assume Nistune style) and running piggy back set ups etc,. I know long time M35 owners already foresee the problems they will have but i'll report back with any info.
Cheers
  • Like 1
Cheers lads
Cheers
I'd be very interested to hear what becomes of your mission!
Really solid. I kept the oem tweeters and run it from headunit. I originally hacked the oem speaker supports to accommodate the kickers but went the mdf supports. Alot more solid and seals 100% more
  • Like 1
you should post a how to josh!
Fitted up a new gear knob... Was over that bulky factory one so went to just jap and bought a $80 TOMEI duracon shift knob drilled out the thread to m12 x 1.75 and put a m12x 1.75 thread on the gear stick... And Voila new gear knob is on!! [emoji3] post-114824-14264742350837_thumb.jpgpost-114824-14264742535469_thumb.jpgpost-114824-14264742633338_thumb.jpgpost-114824-14264743655779_thumb.jpgpost-114824-1426474383985_thumb.jpgpost-114824-14264744152048_thumb.jpg also added a small plastic tab to the gear up and down switches to shorten the travel [emoji16]
Edited by Lakes101
  • Like 4
Yeah you can go stock on the rear like I have or upgrade the rotors to dba slotted or a two pice rotor but all kind of pointless if it just a daily on stock calipers. 350z brembo are a great bolt on option but arnt cheap and r32 gtr or 33 34 gtst calipers are awesome two and bolt strait up with a bolt sleeve
So after 4 years of ownership I sold my M35.
Thought id pass it off still holding the PULP 1/4 mile :whistling:
The new owner is a mate of mine his username is Mrplemith on here. I'm sure he's got a few plans for it maybe cracking the 12's is on his list !!
  • Like 1
Glad I got to see it before it moved on. Stag world will miss ya mate.
  • Like 1
    • Yeah, plenty of air flow, there is a dedicated path that feeds the air in to the OEM intake tube behind the bumper As for a "tangible effect", maybe, but getting the pod/intake air out of the hot engine bay is worth it psychologically to me, even if it gives no performance difference, so the tangible effect in my Lizard brain saysss yessss  In the end, to me a tangible effect isn't always about performance, sometimes it a sound or a look, or even a...... feeling  Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
