Stupid question. Isn't it drivable just by disconnecting it ? Just to make it home and not have to call a truck
sometimes it may enter limp mode, but for my experience, my car kept stall.
Edited by YangLIU
yeah I noticed the fault counter at home and yeah I know that goes into fault mode when taken out of the connector.
towing is free. the insurance company will pay
I was able to drive mine with a blown AFM on all three occasions it happened to me, one trip I was about 100km from home and it got there. I don't know why some cars would be able to be driven whilst some others aren't. Just another M35 mystery.
HDI intercooler ready to be fitte, front lower arm bushes to be pressed in, waiting for m35rv1 turbo and 14psi actuator, new rocker cover gaskets and Lfr7aix spark plugs, b&m trans cooler fitted, banjo restrictors drilled out. Still waiting for mishimoto coolant hoses, nismo thermostat and am performance dump. Cannot wait to drive this thingpost-142568-0-31293300-1460779832_thumb.jpgpost-142568-0-74675000-1460779902_thumb.jpgpost-142568-0-63248700-1460780039_thumb.jpgpost-142568-0-61998100-1460780173_thumb.jpg
What can you read with that unit? And does it work?
Havnt started the car yet as i havnt fitted turbo, but with ignition on i can cycle through rpm, throttle %, boost, water temp, oil temp, oil pressure, injector duty cycle and vehicle speed
Finally found the last pieces to my M35 Stagea 'E' trim code swap. Next will be the head lining in tan.
Not hassling you for it, and I know colours are a subjective thing, but why do you want to swap to beige? My one regret with my Stag is the interior colour, especially since I have kids. It's depressing watching the seats change from sparkling clean to dirty over time, at least the dark interiors hide it.
Edited by Hertz Donut
The lower section of my car is dark (charcoal & black except seats), the top 1/2 is beige/tqn (whatever you want to call it) as it was originally light grey (so this colour is actually darker than what i had). And as i got the burnt orange 350z seats for a steal ($250 - good luck finding a set at this price) i actually dont mind the colour so trying to match to them. edf0e43b45f642ec6ab5053d8cd8f2a6.jpg
As you can see the lower is darker and for a car that wits in the garage 90% of the time doesnt get kiddy grime.
As with all cars they are for individuals and your post is appreciated. Beige interior os so much better than the light grey thats for sure. Oh and i am 1 of 2 m35s (that i am aware of ) who have the rear roof panel not molested by 3 child restraints.
Edited by joshm35
Ah, forgot you had the Z seats, makes more sense now. The 2-tone effect will actually look pretty cool I reckon, almost custom.
Oh lawd, I just had flashbacks to all-white vinyl interiors from the late '90s/early '00s. I wish I hadn't just eaten dinner...
Yeah... sucks they wernt black but the orange is just as nice. Kept all the lower 1/2 black and soon to be completed with black carpet. I was just testing the black headlining but going with a tan colour (cant find a m35 headliner in tan as they all have sunroofs) and i dont have the sunroofs..... yet ;)
Also i have noticed i have a different steering wheel then everone else. Any clue as to what its off?
It's not just the steering wheel, your whole car is pointing the wrong way!
Steering wheel is from a Y50 Fuga, something a bit different, nice one!
Also have a look at the Infinity M35, you might be able to get the cruise switches from the USA.
I'd love a black head lining. That would look great.
You doing it yourself Josh ?
Pretty difficult upholstery job there.
I'd keep it to only 2 colours .
    • Can't you put the pistons to TDC and then do the valve seals? Or will the drop down too far to pull them back up?
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
