I have read the tread a while back i just wondered what he ended up going with.
Cheers lads
Also, nothing that hasn't been talked about enough already, a mob in Adelaide I spoke with last week regarding tuning who have quite a bit of exp tuning M35's are of the opinion that these cars are popular enough to now support. I sent him an email regarding what i hope to achieve and they are gonna get back to me.
The are into keeping and tweaking stock ECU's (i assume Nistune style) and running piggy back set ups etc,. I know long time M35 owners already foresee the problems they will have but i'll report back with any info.
Cheers
  • Like 1
Cheers lads
Cheers
I'd be very interested to hear what becomes of your mission!
Really solid. I kept the oem tweeters and run it from headunit. I originally hacked the oem speaker supports to accommodate the kickers but went the mdf supports. Alot more solid and seals 100% more
  • Like 1
you should post a how to josh!
Fitted up a new gear knob... Was over that bulky factory one so went to just jap and bought a $80 TOMEI duracon shift knob drilled out the thread to m12 x 1.75 and put a m12x 1.75 thread on the gear stick... And Voila new gear knob is on!! [emoji3] post-114824-14264742350837_thumb.jpgpost-114824-14264742535469_thumb.jpgpost-114824-14264742633338_thumb.jpgpost-114824-14264743655779_thumb.jpgpost-114824-1426474383985_thumb.jpgpost-114824-14264744152048_thumb.jpg also added a small plastic tab to the gear up and down switches to shorten the travel [emoji16]
Edited by Lakes101
  • Like 4
Yeah you can go stock on the rear like I have or upgrade the rotors to dba slotted or a two pice rotor but all kind of pointless if it just a daily on stock calipers. 350z brembo are a great bolt on option but arnt cheap and r32 gtr or 33 34 gtst calipers are awesome two and bolt strait up with a bolt sleeve
So after 4 years of ownership I sold my M35.
Thought id pass it off still holding the PULP 1/4 mile :whistling:
The new owner is a mate of mine his username is Mrplemith on here. I'm sure he's got a few plans for it maybe cracking the 12's is on his list !!
  • Like 1
Glad I got to see it before it moved on. Stag world will miss ya mate.
  • Like 1
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
