these came in an awd Y32 cima, Q45 infinity and nissan atlas truck in the US.
VH45DE:
Forged steel crankshaft.
- Forged steel connecting rods.
- 6 Bolt main bearing caps with studs.
- Full-length main bearing girdle.
- Lightweight, floating pistons with molybdenum coating.
- Sodium-filled exhaust valves.
- Cross-flow cooling system.
- Hydraulic lash adjusters.
- Single-row silent timing chain.
- Coil-on-plug ignition system.
- Lifter buckets ride directly on cams to reduce friction.
- Redline of 6900 rpm, Or 7400 RPM's with a modified ECU.
- Compression ratio of 10.2 to 1.
- Bore of 93 mm and stroke of 82.7 mm.
- Dimensions: 890 mm(L) x 740 mm(W) x 725 mm(H).
i was gonna throw one of these in the s14a, but am havn second thoughts after being my mates LS1 powered silvia. scary stuff lol.
i brought this topic up last year. VH41DE retains VCT so is also a good consideration. any thoughts ppl? kgo...
Edited by dirtyRS4
https://www.sau.com.au/forums/topic/349143-v8-vh45de-into-stagea/
or better still, put a VQ25DET into your stagea :P
also, that engine in the pic looks like its setup for transverse configuration and you may need new manifolds. unless the coolant plumbing is very unique
Edited by zei20l
  • Like 1
i agree with Zei201.
fail. dont you mean N/A 3.5 from a M35? :thumbsup:
and even then it wouldnt produce the torque of a 3L or V8 unless you + T. fyi that is just a prototype pic from nissan. it came in rwd and awd configurations iirc.
Edited by dirtyRS4
VH45DE 393NMs@4000
VQ25DET 410NMs@3200
killjoy. lol. as if this is gonna be a standard build. :nyaanyaa: the long run potential with a VH45DET is much greater imo. aiming for around 600hp or more. a variation of this motor was highly developed for indy car in the US.
havent seen many high power VQ motors unless supercharged. jus sayn.
Edited by dirtyRS4
I havent seen many either, its not as common as the VH45DE, it also didnt come out in the states so doesnt have the modding support. that said, there are high powered ones in australia, the titles of those threads start with M35 so you probably didnt read them (no offence intended) and supercharging isnt all that, doesnt give you enough on the top end
is there enough room in the engine bay for the VH? looks like a wide V. whats the angle?
it does fit easily with minimal fabrication. do we have to have this conversation about, " you just cant substitute cubes." and do you really think your M35s are high powered- sif? very rarely do i see you guys forge your motors, running a heap of boost and waiting for detonation. lol, 3.5 manual n/a has much more potential than strapping on a big turbo, mani and injectors on your 2 tonne grandpa mobiles. (offense intended.)
Edited by dirtyRS4
my two tonne grandpa mobiles certainly leaves my sisters 350gt (with a VQ35DE) for dead.. and its not even tuned yet, running the standard ECU
who says grangdpa's are slow?
so it should, but how bout a 3.5 + T. thats my point, lets be crystal clear.
and your fantastic point is?? thats a good photo of you mate. you should just be in your M35. lolski.
Edited by dirtyRS4
i didnt say into the stagea, you mentioned an S14a. S15 would be a better chassis anyway, but either chassis youll ruin the weight distribution.
look mate lets stay on the subject. from wot i have read is a VH41DE has a 56.4% weight distribution ratio in a 240sx. so a VH45DE cant be much more.
back on subject, any reasons why not to put both these motors in a S14a or stagea. some VH or RB info would be appreciated. dirt cheap in the US atm.
Edited by dirtyRS4
Hahaha, there goes dirtyRS4 doing what he can to start arguments.
Of course a 4.5L with a turbo or two strapped to it will give more power than a 2.5L with a turbo.
600hp? No problem on a VQ25, VQ35, VK45... how much cash you throwing at it?
Hell, even old tractor engines can do 600hp with enough cash thrown at them.
There's a 2wd C34 Stagea in town with a VH41DE and there are a few skylines running them as well. I'll try to find some pics and also have a link to "how to" do it.
Have a look in this thread:
http://www.skylinesdownunder.com/forums/showthread.php?t=61576
CCubed who do the R34 kits for stagea's and made our (crappy) roof rails was working on a AWD V8 I think it was the 4.1. The plan was to either single or twin turbo, can't remember. target around 800hp.
I am pretty sure he got to the custom fabrication stage mating the block to gearbox and engine mounts etc.
I am pretty sure he has given up the idea putting it in a stagea or GTR.
He was mainly devel0ping it for his other passion of race ski boats, where lots of power is needed for long periods of WOT. Not many 800hp++ engines can last long going flat out
Give Andrew an email and see if it has developed any further.
It may save you some time.
600hp? Thats no reason to change the dinosaur engine you have. lol.
Im almost there with my VQ25. The VQ35det im currently building would have more potential than your chassis can handle with a much lighter engine than the VH.
Your right- VQ35 is a sissy motor. Can't handle more than 1800 or 1900hp...:action-smiley-069:
clicky link
I think you'd have more success with a VQ35, due to the aftermarket parts variety. Very well supported- almost as much as a John Deere :whistling:
    • haha this shit box doesn't drink coolant, for now       Let me guess, they make heaps of power, use the car for straight line driving and don't care about noise
    • They’re so great that I know of someone pulling one out to go back to a sequential
    • Hello everyone. I've recently started the research into R34 GTR front bits and running into eye watering prices. On the plus site it looks like some places make 'replacement' fender liners for these cars. At eye-watering-but-less than stock prices. I also noticed there's plenty of diffuser options available too. What I would like to know is if my following assumptions are correct. 1) The OEM guard liners are actually only 'half' the liner. They go together with the OEM brake vents which are a separate item which looks to be quite a large 'panel' that is part of the liner. The GTR bumper has bolt holes along the front. I assume the ones in the vent correspond to the ones the OEM liner does not have (circled?)   2) The V-Spec front diffuser supplants the brake ducts in the above item. I am assuming these still work with the guard liners as there's no alternate part that I'm aware of. I don't see how they go together, so I'm making the assumption that they have to, somehow. I know the center splash guard is different on the V-Spec (and is the price of the damn diffuser alone). How does the liner interact with this? 3) There's alternate front diffusers that do away with it all. Annoyingly, a lot of the clones and CF different ones... have no brake ducts on them. I like the idea of them though. My brakes get hot on the track. These alternate diffusers are a lot cheaper than plastic splash guards. I'm assuming you don't have to/aren't supposed to remove guard liners to run a diffuser. I suspect that quite a few people actually do not run the guard liner because with a front undertray you're getting a lot of 'splash' guarding anyway, and most people remove liners given they're probably running a pretty aggressive setup with a diffuser at the front. It would also be nice to know if anyone has ever run the 'reproduction' guard liners and know whether the fitment is OEM quality or "OEM Quality". Example: https://www.ebay.com.au/itm/356254671561 https://carbonetics.net/products/nissan-skyline-r34-gtr-plastic-front-wheel-arch-set Is this knowledge still around?
    • Really, effort is pretty low. You hand fistfuls of cash over to someone else and pick it up when done...   And at least this shitbox isn't drinking coolant right?
    • And most chargers that most DIY people own would put bugger all power back into the battery between cylinders. I've always done it with jumper packs/second battery connected. And that's on any car.   Because race car, and wanting the lightness.  At least in an R33, putting a bigger battery in can at least help shift the weight balance backwards
