Hi guys,I just bought a Skyline R34 GT-T with an aftermarket intercooler installed.
When I bought the car, I didn't or never tried using the AC.On the day I took the car home,I used the AC and it was very warm,specially when idling (like on the traffic lights).
I asked the previous owner and he told me,not really sure what he means but he said that 1 of the AC fan was removed in order to install that intercooler because there was not enough space.
Just curious did all of you who has aftermarket intercooler installed on your car had to take off remove the AC fan ?
Today I went to Autosparks,and they told me that it's very low on gas (freon) but before that they need to check if there are any leaks on the piping,if there are leaks.Then there's no point in regassing until we cover up the leaks.
And the temperature of the compressor is 300PSI higher than usual,he told me that if the compressor keeps working too hard like this.It might break and I have to change to a new compressor which is around $2000 ?
Any advice,tips or informations would be very appreciated.
Thanks.
https://www.sau.com.au/forums/topic/350719-r34-gt-t-intercooler/
On my car I found it necessary to replace the aircond fan with an aftermarket slimline one. if the previous owner has just ditched the fan you might want to think of getting one too, although you might (maybe not) have to pull out the intercooler to install the fan. NB Although if he has also installed an aftermarket aluminium radiator the necessary sensor to switch the fan might be missing and you will have to install a new one somewhere.
new compressor would prob be 300-500 but you could get one on here for 50 or so from other SAU members. if its very low on gas then the pressure shouldnt be 300psi or 300psi higher than normal. maybe it had just been parked for a while and heatsoaked. i have a "hybrid" intercooler and there is about 10mm space between the original fan and cooler. you prob need to measure the gap and see what will fit. stock fan on r33 gtst is about 90mm at widest part and 60mm at bottom edge where its closest
I needed to cut the small lugs on the front of the fan to get clearance for my intercooler on the R33.
The stagea came back without the fan after having the FMIC fitted. Several months later after driving it in hot weather (sitting in traffic) it was apparent there was an issue with the aircon.
I went out and bought a slimline aftermarket fan (like Bob/KiwiRS4T).
Also you will notice that electric fan operates as an overheat fan. Once water temps exceed, I believe 92 degrees, the electric thermostat (located on the RHS bottom of the radiator) will kick over and activate the A/C fan relay which fires up that fan to aid in cooling.
I suggest it gets replaced.
I have a GTT with a front mount and no issue with the stock electric fan, still there and still working....
I would say whoever did the install did a fast simple job rather then spending the time to align it right and do the job correctly...
Put a new fan in there for sure as the A/C will now run hotter due to the intercooler passing hot air onto the condenser....
Do you think I should just go back to the workshop who did my intercooler and ask him to fix it ?
Actually the workshop who installed the intercooler is the dealer who imported my car from Japan (Imports 101) in Perth.
And the previous owner didn't throw the fan,I still have it with me.
I personally would not have accepted that as a job done as they may have finished one job but have created another....
I would take it back and ask the question BUT i would not hold your breathe to them fixing it for free as you purchased the car as it is and the previous owner accepted the work as it was....
At least see what they say and then go about fixing it as they might have a simple solution...
Unfortunately it is probably a cheap china cooler and was just slapped on the car the most simple way - this is no dig at the company as they need to make a dollar and would charge more for better quality, so blame the previous owner for being cheap and accepting it :)
hey guys... i was the previous owner on this car and took it to a few places to see what could get dont i got this intercooler from justjap, and know other people with r34 who have had no problems with it at all as their cars are manual. every workplace i went to said they would need to take the aircon fan out as the automatics have an extra fan for auto transmission cooling or something?
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
