  • Replies 67
Its still at newsagents but some of them are un-reliable or choose not to stock it for some reason? Distributor cant force newsagents to stock stuff.
If you ask them and they wont get it, or you cant find it, then yes, buying online is the easiest way to go.
You guys will also love the R32 GT-R on the cover of the DVD which has its own feature and the credits too......mmmmmmmm...RB26 ear-gasm
There's a little bit of JUN but nothing that shows full potential.
Rob, and I, are putting out the invite again for 2011. Anyone want to take on the un-disputed king of street GT-Rs??
This year we want less talk, more action.
Once event is booked in, I will post up entry forms.
Anyone will be able to fill out the form and then we will select the best 30 odd cars from the forms. Have to restrict numbers and keep quality high as 250kW@wheels stockers aren't really entertaining on DVD/TV.
I'd say the event will be Sep/Oct
also looking at a handling course like TOTB in the UK
lol thanx Dave
the GTR Challenge was the best event I entered into for 2010 ! out of the ones i went to (powercruise 23, sport compac attak, supernats) unfortunately I missed the world time attack !
I would highly recomend ppl get ur GTR's ready bcoz the GTR Challenge for 2011 will be one ultimate event !!!
skills what skills its all in the e85 tune :yes:
HUGE THANX to Andrew and the crew for the hard work they did organising the event :thanks:
Edited by GMASTR
    • The downside of this is when you try to track the car, as soon as you hit ABS you get introduced to a unbled system. I want to avoid this. I do not want to bleed/flush/jack up the car twice just to bleed the f**kin car.
    • But again, the engineers said your cast aluminium would be fine based on the load that would be stretching that section. Same load stretching the bolts in a flex (not the twist), with a much smaller cross sectional area than the original part you've broken. It's why you'd need to be using higher strength bolts, but that's just making up for the strength you lose with less area...
    • I am truly amazed someone on this planet was able to cycle the pump using a scan tool. I've always ghetto cycled them on Nissan 90s shit boxes by slamming the brakes and pulling the handbrake to agitate the rear wheels enough to cause a speed difference
    • I didn't actually try it at the time but a Launch X431 with the appropriate software licenses/upsell will have the ABS bleed function. The Consult II you can still find some old sets of equipment but they're really, really expensive:
    • Well I'll start by saying I'm not an engineer. I am going to go with the KiwiCNC ones.  They are made of 7050 alloy have good fillets and radius.  The material alone is in the order of double the strength and fatigue resistance - Those bolts, once torqued correctly place most of the load at the flat face of the mating surface - the 'stretch' you're talking about through torqueing them up would be far more than the extra stretch 'load' placed on them from a steering input or bump. (in my opinion) so I doubt they would flinch.    - but again "not an engineer".      oh and I don't think stitch welding 7050 is a good idea, likely just weaken the material (from what I read)
