i'm getting a new exhaust and muffler and just wanted to know what ppl think is the best thing to get
i'm looking at getting a Manaflow race series muffler:
#14843
2.25" Inlet, 4" Diam. Tip
2.5" Internal Race Core
Single Wall, Staight Cut
4" Tip Length
14" Muffler Body Length
this any good for a N/A rb25?
and what is best for the exhaust, 2.5 inch or 2 an 1/4inch?? from extractors back
with a cat but no resonator, or should i resonator?
thanks every one!
https://www.sau.com.au/forums/topic/35083-just-a-quick-one-on-exhaust/
resonator is a definite, i agree. Forgot to ask what the guy who replaced mine was going to use - so i ended up with a lukey race hot dog thingy :( .... murder at 110kmh (open road limit here in WA) 3" pipe probly doesn't help... SEVERE overkill on 2L N/A....:looney:
let us know how the change gos... might do the same thing :thumbdwn:
I got a 2.5" hks system with 2 resonators (hotdog resonator and a 2nd small muffler). It works well - not droney AT ALL. The end main muffler is a big barrel style muffler with 2.5" inlet and has a 4.5" tip - it is not straight through in design. I suggest you copy the design of this system (resonators etc) :D
2.5 is definately the biggest u should go, u should get more top end with the bigger diameter exhaust. 2 1/4 is good for low down power. The muffler itself is straight thru yeah ? i would go the 2.25" and a resonator to save ur hearing, but still have it loud :D
Clint
what brand of rear muffler do you gouys use/recomend? i have some Jaz - Jazma ? -can't rember exactly, something like that - i guess it's some cheap Jap brand, but it is straight through, like the resonator, on the extractors with a full 3" cat also...
just one major question, how would you fit an offset muffler in where ther is currently a straight through?
ie how does this;
goto this;
__| |
??? given the way the pipe runs from the engine (tangled round diffs etc.) then fits into that little scallop out of the rear bar?
Jasma is just a regulatory body, like the EPA is Australia. It's not the brand of the muffler, but if the muffler is jasma approved it means it meets certain noise/pollution requirements and therefore is of reasonable quality. For example, my HKS system has a jasma badge on it.
i'm also thinking about a CAT back system - my budget aint that big - but i want something thats going to sound better and increase performance slightly...
i got quoted 290 fitted for a 'home made job', as the muffler place reckons you can't get one to just bolt on? That was for a 2.5" cat back (might only have been the rear muffler)
What kind of system do you guys recomend for 300-350 ish mark?
anything has to be better than stocko one!
PS: Sorry for the post hijack :D
can some of you guys tell me a few price u payed for your systems?
sorry dude, mine was already there... resonator cost me $120, extractors ~$350 i think ? can't remember exactly... the rest - gawd knows !
i have recently taken off my cat back exhaust as i was driving a bit of a road trip. I noticed quite a bit of power loss all through the range.
and Perhaps a week ago, i put it back on, and damn there is power again, noticable low and high in my rev range, but definately more at top end.
Mine is 2 3/4", and its drony in certain RPMs (mainly at 110 on motorway), most of the time, its sexy. Get a big resonator, big as possible imo.
  • 4 months later...
You've probably already got it by now but go a 2 1/2 inch mandrel bent system. I've got a magna flow muffler, #14827, its a single wall angle cut 4 inch tip, but oval shape. I was told they had a slightly better tone and not as droney... not sure if its entirely true. They also fit more neatly under the car, however i was after the cannon style and they do look a bit better. I highly recommend magnaflow though, just ensure you put a decent resonator on as mine hardly does anything and it's fairly loud!
I think I'm going to finally get rid of the Genie Reverse Flow muffler off my car, its just tooo loud! Currently I have 2.5" Cat Back, with a resonator.
Anyone who has done their exhaust cat-back, what muffler and how much was it? An angled canon style would b good, but not really necessary.
I've used a MagnaFlow Street Serious muffler, the exhaust shop were retailing it for 374 but it may be cheaper elsewhere. Yeah the angled cannon style does look good. This one is an oval shape but exhaust shops do the angled bend if you just get a cannon style
Anyone recommend an exhaust shop in the Melbourne city area that fits magnaflow mufflers and will do it for a good price?
When I got the current exhaust/muffler fitted I asked them to put a flange so it can be unbolted, and its 2" up to just before it bends.
thanks!
chicane
Yeah quite a few places sell MagnaFlows as they're fairly reputable and well known. Depends where in Melbourne you are, i got mine done at Casey Exhaust which is in Berwick, they do a lot of work on high performance cars and have done heaps of skylines. The other place i know of that sell them is Dandy Exhausts but your best to just ring around as i'm sure many other places would stock them
I work in Parkville so yeah anywhere close to the city
What other options are there apart from magnaflow (seems a popular brand) for a muffler in the cannon style that will not be too loud, im sick of the drone of my current muffler.. but not too quiet as well (but under limit).
Cheers :)
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
